moon roof: hey guys, help me out...
Old Mar 17, 2005 | 08:21 PM
xkoraznboix's Avatar
20 Year Member
Angry moon roof: hey guys, help me out...
my moon roof (sun roof) will not close. i kept it open while i was driving, tried to close it when i got home, it wont close. it would close 1/5 of the way and stop. have to go somewhere tonight but its going to start raining... what could be wrong? something stuck? motor dead?
Old Mar 17, 2005 | 08:23 PM
Vic's Avatar
Vic
maybe a small rock or something got stuck..
Old Mar 17, 2005 | 08:25 PM
sarcasmo's Avatar
I'm new to the G, but most moonroofs have a manual override that allows you to close the roof using an allen wrench or a key provided by the dealer. Look up the moonroof in the manual to see if it mentions an override. It probably won't help you in the long-run, but it will keep your interior dry in the short term.
Old Mar 17, 2005 | 09:18 PM
EricIsKlumzyee's Avatar
take it to the dealer they should be able to replace of fix it without a problem.. call ahead of time tho
Old Mar 17, 2005 | 10:13 PM
TINMAN's Avatar
instead of close,try open it all the way.then close.if it still doesn't work,bring her in.
Old Mar 18, 2005 | 12:24 AM
escobar929's Avatar
try looking along the track to see if there is anything stuck, usually thats the problem
BTW g's have a sunroof not a moonroof, the difference is that the moonroof goes on top of the car, while the sunroof goes inside the car
Old Mar 18, 2005 | 01:37 AM
20 Year Member
thanks guys for the help. sarcasmo is reply helped me alot. i read my owner's manual about the sunroof and there was a "auto" override. haha! "hold the close botton for 3 sec, wait for a sec, hold it for 10 sec or so, window should be back to normal" and wala~! thing works! i think there was something stuck there, cuz when it started to move, there was a "CRUNCH" sound...
had my car for 2 years and i still havent finished reading my manual ahaha! thanks ALOT guys~!!
Old Mar 18, 2005 | 01:46 AM
Msedanman's Avatar
O.F. Administrator
Be careful not to force it closed. They have been know to shatter given enough force.
It sounds like it's binding either from an obstruction, bent tracking, or skewed glass.
I agree with Tinman's solution, that you should try to carefully open it again, and retry closing. Failing that, get it into the shop for adjustment, and cover it in the meantime or get it inside somewhere to keep it dry.
C.
Old Mar 18, 2005 | 02:43 AM
TopTech's Avatar
I always thought that the difference between a moonroof and a sunroof was that one was glass and the other solid (metal). Thoughts?????
Old Mar 18, 2005 | 03:00 AM
dosa's Avatar
I'm still not clear as to the difference between a sunroof and a moonroof.. I always thought they were the same thing, just personal preference.. what do you mean it goes inside/outside??
Old Mar 18, 2005 | 03:25 AM
Gee Im Fast's Avatar
He means it opens by sliding at an angle outside the car (old style cars 90's) and the other, slides into the ceiling of your car.
Old Mar 18, 2005 | 03:33 AM
dosa's Avatar
Thanks for clearing it up. It makes sense now. My mother's Lexus ES300 came equipped with a "moonroof" and it does slide up and out in an angle.
Old Mar 18, 2005 | 09:51 AM
G3NIU5's Avatar
look in the manual. there's a procedure there to reset the sunroof mechanism if this happens.
Old Mar 18, 2005 | 03:07 PM
TopTech's Avatar
I'm still not buying that inside/outside thing. That came about as cars got smaller and they couldn't spare the interior room to have the roof slide into hiding. How does that make it a sun or moon roof? I think the ability to see thru it makes more sense. Cause before they were glass, they were just sheet metal.
Old Mar 18, 2005 | 03:14 PM
TopTech's Avatar
http://www.stuffclub.org/modules.php...rticle&sid=145
http://ask.yahoo.com/ask/20030617.html
http://www.sunroofs.org/faq.htm
http://www.answerbag.com/c_view.php/1834#q_3225
Googling the question, they all come up with the same answer. Sun=solid. Moon=glass (coined by Ford). None reference wher the roof retracts to.
Cajuncowboy
Jun 21, 2021 09:47 AM
Footballmania32
19 Inch
Jun 2, 2018 07:31 AM
Footballmania32
19 Inch
Aug 13, 2015 03:07 PM
underworld
Aug 6, 2015 01:36 PM
Frostbite91
Jul 27, 2015 05:25 AM
