My G feels a little anemic
Old Mar 22, 2005 | 02:28 PM
GeminiZer0's Avatar
I've had my '04 coupe for just over a year. Over the past few months, it seems to have a little less unf! during acceleration, even hard acceleration. I do need to change the air filter, but I don't think that would attribute to the loss I am feeling.
Unfortunately, I don't have easy access to a dyno, and I don't even know where I would go to put my car on it.
My car has just over 27k on the odometer. Has anyone else experienced the feeling of a loss in power?
I do realize that it could just be my perception and not actually anything causing it. Is there anything I should look for?
Old Mar 22, 2005 | 02:47 PM
KAHBOOM's Avatar
Has it got warmer or more humid in your area?
Old Mar 22, 2005 | 03:22 PM
04g35cNJ's Avatar
thats a lot of wear and tear on a car in just one yr. u might need some things adjusted.
Old Mar 22, 2005 | 03:58 PM
blksnake's Avatar
Perhaps you got a tank of bad gas? Maybe you need a bottle of Techron to clean things up.
http://www.chevron.com/prodserv/fuel...ngas/faq.shtml
My coupe is also a little over a year old and it runs great!
Good luck
Old Mar 22, 2005 | 04:08 PM
SilverII's Avatar
Good luck
Not recommended.... made no difference in my car..... I suggest the ones made by Gumout.
Old Mar 22, 2005 | 04:57 PM
sherwooa's Avatar
Actually, if you're going to use fuel injector cleaner, at least use one that is safe for the whole fuel system. Stick with something like Redline Complete Fuel System Cleaner. Non-corrosive and can help reduce deposits. Try putting in a bottle and then another after 5 more tanks of gas.
As for the loss of power, how would you describe it? Is it hesitation, or just a general feeling that it doesn't produce as much power throughout the rev range? A few things to check:
- Definitely replace the air filter. That can be a significant cause.
- Are your tire pressures OK?
- Have you put in <91 octane gas?
- Have the throttle body cleaned
- Check the coolant level
- Check the base ignition timing. It's possible that it could be off, although unlikely
- Check the throttle position sensor. If it's shifted at all over those 27K (also seems unlikely), it can reduce the throttle valve opening, reducing power.
- Check the plugs
- Check the following sensors: engine coolant temp, MAF, IAT, crankshaft position
- Check for an exhaust leak
Those are the main things I can think of for now. Good luck.
Old Mar 22, 2005 | 05:11 PM
Sandman's Avatar
In addition to the above, you also might consider resetting the ECU. Here's the link from the FAQ & DIY section:
ECU RESETS
Old Mar 22, 2005 | 09:29 PM
Aznteazer's Avatar
just get some mods.....and clean your air filter. that made a big difference.
Old Mar 22, 2005 | 09:57 PM
WRAH's Avatar
WRAH
Have you gained weight?
Old Mar 22, 2005 | 10:08 PM
pinoy702's Avatar
I’m not an expert or anything, just a though that might help. Usually when a car is a year old with 27k think about servicing the fuel filter.
Old Mar 22, 2005 | 10:20 PM
sherwooa's Avatar
Not on these cars. The fuel filter is an in-tank filter that is only to be serviced when there is complete clogging. There is no timetable specified on the maintenance schedule.
Old Mar 23, 2005 | 12:21 AM
patrickwong's Avatar
Hmm....
it's probably cuz you are used to the power.
Old Mar 23, 2005 | 01:47 AM
Omar's Avatar
Head 'n Shoulders
I too feel the same way, but I know it is because we have all gotten used to the power of the G. My track times are actually faster now than the track times when i first got my car, and ironically it feels slower now than it did before.
Old Mar 23, 2005 | 02:48 AM
DiamondGCoupe's Avatar
I sure have, very groggy, crappy crappy, lag between shifts, guess we could use a tune up. *1000*
Marlin84
Apr 1, 2020 12:52 PM
KallDay86
Jan 8, 2016 12:42 AM
prinny
Nov 22, 2015 11:07 PM
Learned Hand
Oct 1, 2015 09:02 AM
aaron3719
Sep 29, 2015 10:12 AM
