HOWTO: How do I replace the steering wheel?
Old Mar 23, 2005 | 07:41 AM
elrooko's Avatar
Lightbulb HOWTO: How do I replace the steering wheel?
Hi All, I got a new OEM steering wheel off ebay (the leather on mine wore out after 1.5 years!!). Anyway, does anyone know or have a DYI on replacing the steering wheel?
Thanks
Old Mar 23, 2005 | 12:44 PM
BlackM6C's Avatar
dealership
Old Mar 23, 2005 | 12:46 PM
Brando's Avatar
Thanks
See if you can send a PM to Canton_G35.......(I know he hangs out on G35Frenzy)
He has installed several for others.
Old Mar 23, 2005 | 12:48 PM
kenchan's Avatar
I haven't looked at the G's steering wheels, but ive done steering wheels in the past.
GENERALLY...
park car with steering wheel straight.
first unplug your battery (-) terminal and hit brake pedal for 15-20 sec.
this is to remove all electricity from the capacitors, etc. so the airbag
does not accidentally depoly.
There should be torex screws around the bottom of your steering wheel
(Might be hidden under cover) remove those and your center of steering wheel
should come off.
Unplug the airbag harness and other control harnesses.
Loosen the center nut about 4 revs, but don't remove it off the bolt.
Pull steering wheel at 3 oclock, 9oclock, then 6oclock, 12 oclock
and it should pop out of its socket. then remove the center nut.
Remove steering wheel.
should be very similar.
Old Mar 25, 2005 | 07:58 AM
JZ39's Avatar
GENERALLY...
should come off.
That doesn't sound too bad. I was always a fan of the 05 steering wheel.
Old Mar 25, 2005 | 08:25 AM
G_RACER's Avatar
For what it's worth,the leather on my steering wheel started to crack and wear out where I positioned my hands during driving. I have an 04 AT. I took it back to the Infiniti dealer who agreed with me that this was a defect and would be replaced under warranty. I waited a couple of weeks as the part needed to come from Japan. The replacement steering wheels is fine. Hope this helps someone.
Old Mar 25, 2005 | 09:32 AM
dgbos4's Avatar
I had the same problem - steering wheel and shifter leather wore out after 1.5yr and the dealer said when I come in for my 30k mile service they will replace both under warranty.
Old Mar 25, 2005 | 09:39 AM
kenchan's Avatar
Yah, it's pretty easy.
Luisgalvan33
Jul 19, 2018 08:16 PM
kd03g99
Jul 30, 2015 11:24 AM
Luisgalvan33
Jul 28, 2015 05:37 PM
rping
Jul 26, 2015 09:53 PM
