How do you guys do your oil changes... where?
Old Mar 28, 2005 | 12:08 PM
P_Diddy's Avatar
The problem w/ changing the oil yourself is that it's a major PITA. Need to get a jack or ramps to lift the car up enough, then you need an oil pan to catch it all, then you have to dispose of it.
gto2050, i've taken it to jiffy lube and i watched them. I was impressed by how they treated my car! he didn't take the entire underbody engine cover off though, he took off the rear 2 bolts and bent it down a little, but it worked. and then I watched him screw the bolts back in.
Old Mar 28, 2005 | 12:46 PM
Finiti35's Avatar
FGC South Florida BOD
Originally Posted by gto2050
I still take the easy route and go to the Infiniti dealer. Not a big deal. I don't trust the jiffy places because of the underbody aero diffuser. I figure they won't put all the bolts back.
I'm sorry I'm missing something, but how is the underbody diffuser related to changing the oil? Never really looked at the underbody...
Btw my dealer charges $50 for non-synthetic oil... Nissan here we come, can't beat it for $28 and it goes on your service record too.
Old Mar 28, 2005 | 01:53 PM
gto2050's Avatar
The underbody diffuser covers the oil drainage plug. I have never removed it but it has many bolts holding it in. As P_diddy says....they took two out and bent it down a little to get to the drain plug.
Old Mar 28, 2005 | 02:18 PM
G35Mechanic's Avatar
The diffusers are on the rear of the under body. The cover under the engine is somthing thats on all infiniti products.
Some guys only take out the one screw in the corner nearest the filter and drain. You can drain the oil without taking out any of the screws, thats why there is that hole in the cover. Then you take out that one screw so you can reach in and take the filter off. Other guys just take out the first 4-6 screws and drop the whole cover, it takes a little longer to remove all the screws, but its easier when you dont have to reach in to a small area for the filter.
Mry
Mar 3, 2023 01:03 AM
bTanz
Oct 15, 2015 02:31 PM
Gookiecrunch
Aug 19, 2015 12:00 PM
ghost_g35
Aug 7, 2015 10:31 AM
