setting lock and unlock flash
Old Mar 30, 2005 | 04:59 PM
pointman1's Avatar
guys, question. to set the headlights to flash when locked and unlocked WITHOUT the horn, does anyone know the exact settings??? The dealer has no clue. i watched him fumble with it for an hour and yield no results.
update on horrible mpg. as some of you know, i have been getting ridiculously low mpg. i went to two different dealers today... first one, "its normal, you are in spec." Second dealer (without even touching my car) "you have a g35 coupe, i know you push the car hard. plus, its winter. gas stations use oxygenated gasoline. its normal."
Old Mar 30, 2005 | 07:34 PM
gary245's Avatar
hold both lock and unlock for about 2 seconds, the lights should flash 3 times. Do it again to reverse it. it's in the owners manual...
At least for my 2005 sedan...
Gary K
peter_c's Avatar
press 'unlock' and 'lock' at the same time for a few seconds
Old Mar 30, 2005 | 07:51 PM
DeStreGa5's Avatar
instructions are also in the small manual
Old Mar 30, 2005 | 08:36 PM
dave's Avatar
The headlights will not flash when you lock or unlock the doors. The posts above will get the parking lights to flash.
There are other settings that you cannot set yourself. The dealer can set them using the consult tool. Details are available in the FAQ
Old Mar 30, 2005 | 11:50 PM
pointman1's Avatar
guys i did that.. and the only thing that happens is the horn goes away, and the parking lights NEVER flash.
Old Mar 31, 2005 | 01:14 AM
pointman1's Avatar
i checked the FAQ's section, thanks for the link.
Can i tell the tech to simply set it to MODE 4???
Old Mar 31, 2005 | 09:42 PM
dave's Avatar
If the parking lights don't flash when you click the lock button on the remote, something is wrong.
That might work. I think it's a good idea to be very specific about what you want done to the car. I would print out the sheet, and mark how you want it set, and give that to them.
Old Apr 1, 2005 | 11:12 AM
pointman1's Avatar
thanks Dave, will do.
tal1412
Nov 28, 2022 09:25 AM
SiMpLyMoDiFiEd
The FX-Spot
Dec 2, 2021 04:35 PM
laksjd84
Steering & Suspension
16
Jul 12, 2017 12:22 AM
xluke
Jul 30, 2016 01:48 PM
Team STILLEN
Aug 10, 2015 08:17 PM
