Handbrake
Old May 22, 2003 | 09:59 AM
GforceI's Avatar
G SQUAD
Handbrake
Ok I am pretty sure that my hand brake needs to be adjusted. I usually do not leave the car in gear and tend to rely on the handbrake unless I am on a steep grade. It seems that even when I am on a slight hill If I dont crank up on the handbrake I start to Roll. Checked the manual and it says 6-7 clicks should do it but I'm up around 12-13 to make it effective. Anyone else have this experiance?
Old May 22, 2003 | 11:18 AM
jeffjcalweb's Avatar
Re: Handbrake
me three. its a little annoying as my wife complains that i set the brake & she can't release it. or maybe that's just infiniti's way of protecting our cars!
Old May 22, 2003 | 11:42 AM
hoshtaylor's Avatar
Re: Handbrake
Gforcei,
Can I make the suggestion that you put your car in gear from now on...? I used to be the same way and only use the parking brake...and it only takes one time to forget...especially in a parking space that you think is on flat ground...this happened w/ my old car...parked my car, went up to the apartment and 5 minutes later got a call from the front office that my car was "blocking the exit gate." Not so good...needless to say, not only was my car f*cked up, but the two others it rolled into as well...needless to say it was a pretty expensive mistake and trust me...it will never happen to me again...I always leave my car in gear and put the brake on now.
"Operator, give me the number for 911!"
- Homer Simpson
Old May 22, 2003 | 12:43 PM
probepro's Avatar
Re: Handbrake
I use the suspenders and belt solution (in-gear and handbrake). I just made it a habit and I never have a problem.
Old May 22, 2003 | 12:50 PM
rstark's Avatar
Re: Handbrake
I agree that the car should be in gear when you use the handbrake, but the brake should be more effective with less effort when engaged. If there's a fix for this, I would like to know.
-Rick
Old May 22, 2003 | 12:57 PM
BONDg35c's Avatar
Re: Handbrake
Not only "in gear" but in 1st or reverse. you'll notice, if you care to experiment, that if you put your car in a higher gear on a hill without the handbrake (engine off, of course) and let out the clutch, most likely the car will move forward (or backward, whichever way the hill is facing).
Also, I'm not sure if this is true or where I read it, but supposedly you can adjust your brakes (maybe not including the handbrake) by backing up and applying the handbrake. I know it used to be that backing up and applying the footbrakes used to adjust the wheels.
Anyone have any current info on regular brake adjustment?
Old May 22, 2003 | 01:05 PM
gumpdriver's Avatar
Montgomery's Finest
Re: Handbrake
yep....I have had that happen to me to stop the car from moving on a decline or an incline....Tips on this are very welcome...
Old May 22, 2003 | 02:08 PM
Msedanman's Avatar
O.F. Administrator
Re: Handbrake
There is an adjustment but has to be done at the dealership.
<font color=green>GSM</font color=green>
Old May 22, 2003 | 02:41 PM
darren's Avatar
Re: Handbrake
I had the same problem. It seemed like I had to practically rip on the handbrake to get to engage on a hill. I took it to the dealership and they said (surprise, surprise): "It's fine." Well, my other cars don't have difficulty staying put on the hill. Solution is as outlined here -- torque on the e-brake and leave the car in 1st or reverse.
6MT
Premium
Black/Black
Old May 22, 2003 | 02:54 PM
RamboRami's Avatar
G35driver.com Moderator
Re: Handbrake
yeah i prefer to leave mine in reverse+handbreak, the reason i choose Reverse rather than 1st gear is because that gear is used MUCh less than first, so i dont want 1st gear to wear out before the others do (especially the notchiness, i wouldnt want 1st gear to be gooey but then all the other notchy)
<font color=green>-Leblau Timmaw</font color=green>
Old May 22, 2003 | 03:32 PM
GforceI's Avatar
G SQUAD
Re: Handbrake
I only put it in gear when I am on a definate hill. It's a habbit for me to leave it out. I dont think I can change. In the manual however it does say the number of clicks that the handbrake should need to grip and I am way over that so I figure it needs to be adjusted but I guess the dealership will determine that one and if it doesnt I suppose I'll have to break an old habbit. I must say I did expect the handbrake to be tight and not sloppy like it was in my last car. Hopefully It can be adjusted and al will be well.
Old May 22, 2003 | 03:38 PM
Msedanman's Avatar
O.F. Administrator
Re: Handbrake
Not fine. Go elsewhere and have them adjust it bro. Those cables stretch, so they put adjusters in them to compensate.
mtlruss
Lighting
Sep 9, 2015 07:44 PM
RA081024
Aug 18, 2015 07:03 AM
willmkent
Oct 19, 2013 03:17 AM
G-Bus
Jan 4, 2010 06:26 PM
CalsonicVQ
Aug 8, 2007 01:22 PM
