Passenger window issues
Hi guys,
Today, when I tried to lower my passenger window (I always click it so it goes all the way down) it didn't go down at all, I thought maybe my passenger window was on LOCK, but no luck either way. Granted it has been a hot day, dunno if that has anything to do w/ it... after trying it a few more times while driving down the street, it went down, but STAGGERING down... then after a few tries it went down smooth....
Now the passenger window has always been a bit slower than the driver's window, I always thought it was probably cuz of maybe a bit thick of tint on the passenger side...
My question is... will the dealership cover this under warranty? And will it presist afterwards?
Thanks
Thanks
Thanks! The motor just died acutally, I can't roll the window up, I had it down (not smart) and it died on me... is there a way to manually roll it up? I have an appointment w/ the dealership on MONDAY... that's about 3 days from now, I really need to have my windows up for safety issues, any ideas?
Thanks
Thanks
Thanks
Thanks
this just happened to me about two weeks ago. the dealer will definitely cover it, and it only takes about two hours to fix. i was worried when it happened, but it was no big deal at all to get fixed.
as far as getting your window up...pull up on the window button, and tap the door panel, right in the middle at the same time. the window will come up, but leave it up until you get it fixed.
I used to work for the US version of the company that makes the Window Regulators for Nissan. If the motor is bad, the only way to get the window back up is to take the panel off and maually push the window up whilte trying to turn the drum that the cables wrap around. Not sure why the motors would be bad. Usually we found that the friction from the door sashes (glass rails) was too much, and the glass was too heavy from what the torque used to design the motor. The friction from the sashes may be the reason that banging the inner door panel will "break" the glass lose so it can be rolled up again.
Originally Posted by jayco
i've heard this will at least get your window up. just make a fist and bang right in the middle of the interior of the door, above the armrest.
yeah, my passenger side window is shot as well. It only goes up/down when it feels like it... and get this.. both sides have been replaced before. Oh well. I have to punch the middle of the door to get it to roll back up. humiliating when you have a girl in the car with you.
Micale757
Lighting
Apr 8, 2020 10:46 AM
