Oil Question
Old Apr 21, 2005 | 11:20 PM
Powashiftin's Avatar
Oil Question
Ok I recently checked my oil (10 minutes ago) and noticed the dip stick didnt register any oil. The car was cold too! I said WTF. I have 1700 miles on my '05. I want to top it off, but I don't what happened to the oil. Is it possible that it was burned up or consumed? Is that even normal? This is my first NEW car by the way and i'm tempted to even call the dearlships service department tomorrow morning. I did a search, but nothing came up. Maybe the search engine is screwy, I dont know. Any help will be appreciated guys.
Thanks
Old Apr 21, 2005 | 11:25 PM
WolfsterX's Avatar
I think you need to warm up the engine, and then turn it off...then check the oil dip after 10 minutes.. Oil Dip is the pain in the ****!
Old Apr 21, 2005 | 11:27 PM
I checked when the engine was warm as well- Same deal
Old Apr 21, 2005 | 11:28 PM
WolfsterX's Avatar
Then i have no idea, maybe you should call up your dealership and get oil change. It's free at first oil change.
Old Apr 22, 2005 | 12:42 AM
EZZ's Avatar
EZZ
Take it to the dealer as soon as possible. sounds like you may have one of the very few VQs that have the oil consumption problem.
Old Apr 22, 2005 | 01:02 AM
htownboy's Avatar
My G was prepped at another dealer then driven across town; I drove it home and started looking & checking; had the same problem; drove right back and they had to add over 2 quarts... I was told the car was improperly prepped at the originating dealer... Sound like bull?
I have 19500 miles now and all is well; no oil consumtion and my dealer has been great except for that one oversite; I am quite pleased with the service there.
Old Apr 22, 2005 | 01:18 AM
EricIsKlumzyee's Avatar
just keep an eye on your temp guage.. if anything goes wrong its all on the dealer so yeah.. the needle should be a little below center.. Also our dipsticks are a little hard to read..
Old Apr 22, 2005 | 02:10 AM
pointman1's Avatar
"a little hard to read" is probably the understatement of the year. its a puzzle to pull it out straight.
when is the proper time to check.. cold or a little after warm???
Old Apr 22, 2005 | 03:16 AM
umm doesnt matter.. when you drain everything and replace the filter you'll fill up the oil to the correct level then start your engine.. this will cycle your new oil through and fill up your new filter causing the oil level to decrease..
basically run your engine (let it cycle through), then turn off your engine and let everything set.. about 2-3min before checking it again or else you'll get an accurate reading..
if you want a tip bout reading the dip stick.. it'll help if you put it under light and look for the glare.. theres nothing wrong with it cept its placed in a weird position but yea
Old Apr 22, 2005 | 10:40 AM
speedgeek's Avatar
Hi,
Just want to make sure your car was on a level surface (no sloping driveway) when checking the dip. If the car is not level, you’ll get inaccurate reading. I always check mine when the engine is cold on a level surface.
I'd contact the dealership either way, better safe than sorry.
Good Luck
jsimonk
Dec 22, 2023 03:49 PM
RA102223
Aug 15, 2015 09:24 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
