Tiptronic How Often?
We don't have 'Tiptronic' transmissions. You want a Tiptronic, buy a Porsche.
I use the manual mode of my 5AT probably 40% of the time I'm behind the wheel. Depends on traffic, what I'm doing, etc.
I think you could use your manual mode as it's designed 100% of the time with no ill-effects. No reason to think otherwise. Treat it like you would any manual and it'll be fine, only it'll be smoother and have less vibration LOL..
ditto on vin's comment... i use MM around 70-80% of the time. only time i don't use it is either a) stuck in traffic or b) long highway cruises
damn, i guess i should have just gotten a 6MT instead
-Vin
It's NEARLY the same as having a real MT
I tried the system out in a loaner Sedan. I found leaving it in Auto was better overall. The shifting was too lazy(delayed) to use with ease. You really need to anticipate the shifts for performance driving. I'm sure it would be easier with more time with it, as I was a bit clumsy with it, but I definitely prefer my 6MT.
As far as it's effect on performance, I see no reason why it would cause any problems with durability other than the wear and tear associated perhaps with keeping revs high if thats how you use it.
Guest
Posts: n/a
I use it when I cruise on the weekends [because of all the stops and starts and how it will stay in 3rd gear till 10mph - less shifting] or when I'm in parking lots so it wont ever shift out of 1st as I never go any faster then 15mph anyway. I love the thing and I have gotten pretty good at it where the shifts can be smoother than when I'm in D if I want them to be.
