Lost Key McGard Wheel locks?
Old Apr 28, 2005 | 06:52 PM
G35COUPEBC's Avatar
Unfortunatley I lost my key for a set of McGard wheel locks (Under Hub Cap style lock) on my 18" factory rims and I'm wondering has this ever happen to anyone?
http://www.mcgard.com/search/default...avID=1&NavID=8
I heard tire shops might be able to airblow/pry them out, however I'm worried my rims may be damaged.
Any help would be much appreciated!
Thanks!
Old Apr 28, 2005 | 07:01 PM
RBull's Avatar
Rated M
Thanks!
Do you have the code so that you can get a replacement from McGuard if you are not in a hurry?
Old Apr 28, 2005 | 07:30 PM
afr0puff's Avatar
Supa Dupa Moderator
You should have registered your lock set. They would have a replacement for you in no time.
Old Apr 28, 2005 | 08:17 PM
JohnnyCham's Avatar
go to your dealership or any infiniti dealership. they have a master set for stuff like this. and you can buy a new set while your there. no need to risk damaging your rims trying to pry them off.
Old Apr 29, 2005 | 11:00 AM
Inf4life's Avatar
i had the same thing happen to me and i just went to the nissan dealership and they had a master set to get it off and they ordered me a new lock key..... it cost like 13 bucks....
Old Apr 29, 2005 | 01:18 PM
XCELR8's Avatar
When McGard was here they said the best way to obtain a key, if you lost or didn't send in the code, is to contact them. Sometimes they can cut a new key with a very high res pic of the lock face. Better way they said is to send them an imprint of the pattern via styrofoam coffee cup or putty. Finally, making a rubbing of the lock surface works sometimes as well.
Old Apr 29, 2005 | 02:44 PM
cfl70's Avatar
Call Mcguard At 18006698788.they Can Get You Another
Old Apr 29, 2005 | 04:21 PM
SilverII's Avatar
i lost my dad's recently and all I had to do is to send the code and $15 .... got it in 2.5 weeks!
tal1412
Nov 28, 2022 09:25 AM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
apintojr
Jul 23, 2015 10:52 AM
