Please Help.........window Stuck
Old May 10, 2005 | 10:41 PM
truplay8's Avatar
THE BATMOBILE
hey my window has been acting up and i decided to leave it up by putting on the window lock. And by accident my friend held the unlock button down 3 times, and down goes the window. It is permanently down and will not go up no matter what. I am on a tight schedule and dont have time to get to Infiniti any time this week. So can anybody tell me a way to put the window up manually or some sort of trick to get the window up???
thanks
Old May 10, 2005 | 10:45 PM
neal540's Avatar
I doubt this is the case, but make sure you don't have it locked still and are mistakenly thinking that it is unlocked. That happened to me, I was like WTF is wrong with the window, and I realized I had accidentally locked it...I'm sure since you mentioned lock though, its prolly not the case, but can't hurt to double check..
Old May 10, 2005 | 10:48 PM
G6MT's Avatar
G'z 6MT
From: Mo-town(Modesto) Bay Area (Silicon Valley), CAL
Check to see if you still hear the motor working. If it does try to gently pull-up while your press the window button.
Tempary fix
Old May 10, 2005 | 10:54 PM
truplay8's Avatar
THE BATMOBILE
when i hit the up button i hear a click but nothing happends
Old May 10, 2005 | 11:00 PM
G6MT's Avatar
G'z 6MT
Sounds like your motor to your window is out.. or possible relay.
Call your dealer/technician to confirm
Old May 10, 2005 | 11:46 PM
dominoedge's Avatar
It happened to me during the winter while paying toll. Rolled the window down and it didn't roll up - all I heard was clicking. This was in Chicago during the winter, so it was like 0 degrees ourside. Drove a bit, decided not to freeze, then called for roadside help.. They came and towed the car. It took about a day to fix.
Old May 10, 2005 | 11:51 PM
papagz's Avatar
what year is your G? i just had my window motor replaced in my 04. 03's and 04's have that tendency. i also had to have the car on a tight schedule, and was told a temporary fix would be to hit the area wher the motor is located. a little above the slot on the door. just hit it and see if it goes up. usually motor just needs a kick
Dallsinghjr1
Sep 17, 2023 11:25 AM
Albanian122
Sep 12, 2015 04:02 PM
jbmw002
Sep 10, 2015 12:54 AM
