Clean Engine Bay
Old May 11, 2005 | 08:58 PM
HipHopPro's Avatar
Clean Engine Bay
Holla,
How do you guys/gals clean your Engine Bay? That's if you keep it clean.
P.S. I did a search.
Old May 11, 2005 | 09:47 PM
RPMZ's Avatar
I cover up all electronics, take off engine cover, and spray litely with a hose and sum mild degreaser. Very lightly. Then use cleaning wipes, detailer spray, and tire shine whipes for the hoses. Hope that helps, little brushes help too.
Old May 11, 2005 | 10:11 PM
HipHopPro's Avatar
Thanx for the reply. I'll try that.
Old May 11, 2005 | 10:41 PM
GlenRoseFireFighter's Avatar
a.k.a. RANDYS_G
I cover up the electronics, filter for SC and use a high pressure washer...then, I use an air compressor to blow all standing water away.
Old May 12, 2005 | 01:14 AM
TopTech's Avatar
never clean it. wouldn't buy a used one that was cleaned either. normal dirt will show there was nothing abnormal in the long run. but for show would be something else.
Old May 12, 2005 | 02:01 AM
cungkpham's Avatar
dont brush your teeth then.... bc they are gonna fall out eventually any ways... but for a date would be something else...
Old May 12, 2005 | 04:12 AM
SoCalTed's Avatar
connect the garden hose to the water heater in the garage.
use an attachment that let's me mix a little degreaser with soap.
Don't cover anything, but then i don't open/spray the btty compartment or soak the belts or alt.
use a towels to dry heavy water, then finish with the leaf blower
Works great.
Cheers, ted
Old May 12, 2005 | 08:12 AM
XCELR8's Avatar
Originally Posted by HipHopPro
Holla,
I pay someone
Old May 12, 2005 | 08:19 AM
spendgy's Avatar
Go to autopia.org and look for some detailing tips there.
My only advice on top of everything that has been said here is to let the engine come up to normal operating temperature to assist in the removal of the built up grime.
Old May 12, 2005 | 09:32 AM
Msedanman's Avatar
O.F. Administrator
Same as RPMZ, but make sure all the electronics are covered properly, and don't spray too much or too hard.
C.
Old May 12, 2005 | 01:35 PM
TopTech's Avatar
Someone has sand in their vagina!
Old May 12, 2005 | 01:39 PM
a.k.a. RANDYS_G
that's also a great way to crack your block....introducing COLD water to a HOT block CAN crack it.
Old May 12, 2005 | 10:19 PM
cungkpham's Avatar
i assume you know how that must feel like.
zoop425
Mar 29, 2016 05:51 PM
pigpen infiniti
Aug 16, 2015 09:07 PM
