20 Inch Flat Tire
Old May 11, 2005 | 11:00 PM
kdiesl's Avatar
20 Inch Flat Tire
I was driving on the highway when i heard a noise coming from my rear drivers side tire. I pulled over knowing it was a flat. When I got out the rear tire was smoking I changed the tire and noticed that the tire was ripped in the inner side of the rim. Anyone ever had this experence or knows why the tire was smoking.
Old May 12, 2005 | 01:16 AM
codeflux's Avatar
oh damn... could it have been rubbing somewhere?... glad you and your G is one piece - it could come out much worse.
Old May 12, 2005 | 01:23 AM
bkchang79's Avatar
yes this happened to me, once you drive on flat tires your tire will wear from the inside.
Old May 12, 2005 | 11:34 AM
coolnesh's Avatar
just what bkchang said.
inshort that tire is toast. You will need to replace it.
Old May 12, 2005 | 12:22 PM
SilverII's Avatar
blame it on the low profile...
Old May 12, 2005 | 12:53 PM
JReedG35C's Avatar
More importantly did you damage your rim? I'm worried if I ever have a flat I'll damage my lip. Did the rim touch the ground?
Old May 12, 2005 | 01:17 PM
Msedanman's Avatar
O.F. Administrator
You must have been driving on it for a while and not noticed it. The car seems fairly stable with a flat. Rubbing on the body work would have caused it to smoke.
C.
Old May 12, 2005 | 01:23 PM
WolfsterX's Avatar
It's better to keep the air pressure sensor that will keep us inform of the low air pressure in any of the tires.
Old May 12, 2005 | 04:49 PM
6969g35's Avatar
From: FROM BROOKLKN NEW YORK NOW LIVE IN VALENCIA CA.
yes same thing happen me
but bent the rim and ruin the tire
those 20s very sensitive
Old May 12, 2005 | 04:57 PM
Hotrod's Avatar
The most probable reason the tire was smoking is that once it went flat all of the forces were on the outer edges of the tire and that will cause the tire to get very hot. Even low tire pressure will cause the tire to run hot at highway speeds.
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
zoop425
Mar 29, 2016 05:51 PM
ResoG35Sedan
18 Inch
Nov 11, 2015 04:26 PM
GBoy
The Q - Spot
Sep 5, 2015 03:15 AM
realtalk21
Jul 20, 2015 09:07 AM
