Driving Styles to maximize Fuel Economy
Old May 12, 2005 | 12:44 PM
urabus's Avatar
For you M6 owners...
What rev's do you find best to optimize your fuel economy for highway driving?
When you are driving normally, at what rev do you normally shift at? You know, when you're not street racing or trying to show off the nice sounding exhaust?
Old May 12, 2005 | 01:42 PM
P_Diddy's Avatar
i don't have a bmw m6, but I do have a 6-speed tranny, if that's what you meant
Around town, I'll shift at 2500 or 3000 rpm. Sometimes I'll skip from 2-4 & 4-6 so I don't have to shift 6 times.
for highway driving, the slower the better if you are concerned w/ fuel economy. 80mph is 3000 rpm.
Rookie84's Avatar
For highway driving, just leave it in 6th... the revs depend on the speed, so there isn't really a point asking what revs would give you the best mileage. I normally drive at about 5-10mph above speed limit on highways.
I normally shift up between 2-3k rpm. I also leave the car in highest gear possible when crusing at certain speeds.
My MPG according to my Navi is about 20mpg On long, highway trips, it's about 24-25mpg.
Old May 12, 2005 | 03:08 PM
EricIsKlumzyee's Avatar
i'm kinda on a big hill.. so going downhill i'm at 6th gear once i get pass 35mph-ish..
uphill.. depending on steepness shift at around 2.5
and it is possible to drive under 2k rpm with a light foot.. and play slow music while having your head on the head rest usually does the trick
Old May 12, 2005 | 03:15 PM
98intrigue's Avatar
I've tested my mpg out a few times... It seems that when I shift between 2000-2500rpms, I still receive the same gas mileage (per tank) compared to when I drive aggressively. I always end up around 20mpg no matter how easy/hard I drive the car.
Old May 12, 2005 | 03:33 PM
P_Diddy's Avatar
2.5 seems low for uphill. lugging your engine is bad. once you upshift, is the engine making a lot of noise or is it accelerating?
Old May 12, 2005 | 03:45 PM
giddyup69's Avatar
why not follow infiniti's recommended shift points? i find them fascinating !
Gear change MPH (km/h)
1st to 2nd 8 (13)
2nd to 3rd 16 (26)
3rd to 4th 25 (40)
4th to 5th 28 (45)
5th to 6th 33 (53)
Old May 12, 2005 | 04:13 PM
Finiti35's Avatar
FGC South Florida BOD
In Canada Infiniti decided to call the 6-speed manual M6 instead of 6MT. Go figure..
Is it good for the car to be underpowered though? I always try to keep it at at least 2k, if not I downshift.
Old May 12, 2005 | 04:31 PM
RBull's Avatar
Rated M
Sorry my friend "M6" Coupe model is actually used in the Infiniti brochure and web site for us Canucks, so if you're thinking that's BMW you better call Infiniti Canada.
I can't speak for you yanks though.
I used to have that on my signature until I had some US friends that couldn't get it so I changed up.
Old May 12, 2005 | 04:34 PM
NovaJay's Avatar
Floor it & shift at redline everywhere you go. That way you'll get to your destination faster & spend less time on the road. Less time on the road = less gas used.
Old May 12, 2005 | 04:42 PM
you'll notice our engine start to "boggle" about 1k ish while trying to accerate.. for an motor that pushes 300hp its as easy as eatting cake to hold a speed on a flat road..
by uphill i do not mean mount something..
but as long as your accelerating your bring your fuel economy down.. idealy.. if you can.. try to drive from point A to point B withOUT using your brakes or pass the half way point on your throttle..
basically go by feeling.. for the new stick drivers the G is a pretty hard car to feel anything.. if you screw up somewhere the nice gear box and insulation will fix it. Just drive more and it'll get easyer... or go get a POS 1990something with no insulation and a pissed off tranny and try to drive that.. if you can make your ride quality next to decent then you can consider yourself a pretty good stick driver
Old May 12, 2005 | 05:13 PM
Gee Im Fast's Avatar
Accelerate slowly and don't floor it when coming out of a stop. On the highways, 60-65 mph gives you max mpg. I get 27mpg (sometimes 28!)according to my NAV when driving on freeways at that speed...but again the NAV is just digital and based off of formulas, so I subtract 2-4 for real mpg.
Old May 12, 2005 | 05:36 PM
what does your navi says between 90-115
Old May 12, 2005 | 06:22 PM
TheGest's Avatar
Gangster Member
redline 8 rpm every gear, it works great
TheGest's Avatar
Gangster Member
27 on NAV damn, highest ive seen is 20, damn you guys must be feather footed
