Hp Gain Numbers W/o Forced Induction
Old May 16, 2005 | 07:59 PM
GBousis's Avatar
I know a few of you wanted to know what are some common gains in hp / tq without upgrading to a turbo. Here is the nice and positive approach to your questions rather than a rude approach. These are numbers I found by companies with the following performance parts.
Headers: +15 hp / 18 tq $600
Cams: +13 hp / 15 tq $1000
Grounding Kit: +5 hp / 3 tq $100
Test Pipes: +16 hp / 20 tq $289
High Flow Cats: +9 hp / 12 tq $455
Pully's: +15-18 hp / 20 tq $324
Exhaust: +14/18 hp / 18 tq $1000
Intake (Cold Air): 14 hp / 12 tq $250
Your looking at a potential $4000 dollars in upgrades coming out to + 108 hp / 118 tq w/o a turbo imagine if you put all that plus a turbo you would be over 500 without any reasonable doubt. So if you have 10,000 to spend towards speed go for it! With some turbo kits you might be able to almost hit 600 which would be insaine!
Others for non hp:
Tein Coilover Shocks: $1700
Sway Bars: $269
Btw. Question what does the HKS Racing Succion Kit exactly do?
Old May 16, 2005 | 08:17 PM
kenchan's Avatar
How about $500 and net you 50-60hp at the crank? (nitrous)
Old May 16, 2005 | 08:20 PM
spendgy's Avatar
I'd say most of those numbers are overly optimistic...
Old May 16, 2005 | 08:21 PM
jnkirk1974's Avatar
Fastest G35 In Rockwall
I think all of this seems good in theory. However, most people find that they do all of these add-ons and then it amounts to minimal gains. Many dynos have shown this.
Obviously, there are gains to be made with everything you listed. However, I think someone would be hard pressed to get 108 HP out of all of them combined.
If someone could prove to me that all of those would create 108 HP, I would much rather do that than forced induction for the sake of putting less stress on the engine.
Can someone confirm whether or not all of these can produce this type of power? If so, I'm doing some shopping!
Old May 16, 2005 | 08:29 PM
GBousis's Avatar
Numbers
I checked these numbers with sites such as stillen, intense power, bullet proof all of them listed numbers like these. If you give or take a few horses here and there even if they all added up to 108 hp and 120 torque, give or take say subtract even 30 horses thats still 78 horses and 90 torque which is still insaine considering its a lot safer, and puts a lot less stress on the engine while still sustaining the warrantee.
Old May 16, 2005 | 08:31 PM
bzabodyn's Avatar
HAHAHA! THIS IS ONE FUNNY A$$ POST!!!
j/k man, I have every single bolt on besides cams (which I don't consider a bolt on - much like headers, as the labor factor involved in extremely high)... anyways, I dynoed around 218-220 stock and before the headers I was at 252... and I think I've had more actual gains than many others (each additional part I installed actually gained hp if you can believe that!) it's been almost a year since I dynoed, and I'd like to see what the curve looks like now that I've swapped out rear ends... I'd be ecstatic if I hit 260... (a 40hp gain with only bolt-on's is almost unheard of on this car) - trust me, I've done it, and the "ricer math" you implied above only adds up on paper...
Old May 16, 2005 | 09:00 PM
g35doc's Avatar
You need to subtract the 5hp from the grounding kit (no gains) and multiply the others by 1/2. Even then it's still somewhat optimistic.
Old May 16, 2005 | 09:28 PM
mc2's Avatar
mc2
so then i would have to ask, what the hell is the point??
Old May 16, 2005 | 09:38 PM
Stealthy_G's Avatar
I think what everyone is trying to say is that "forced induction" is the only unquestionably effective method to making more power. The above mod's will more likely improve the performance of a FI car rather than NA car. -minus the grounding kit of coarse
Old May 16, 2005 | 09:40 PM
truplay8's Avatar
THE BATMOBILE
i agree
Old May 16, 2005 | 09:56 PM
Stealthy_G's Avatar
bzabodyn,
Was the Plenum worth it? Did it make a difference?
In your opinion what was the best bang for the buck mod? Thanks
Old May 16, 2005 | 10:19 PM
WRAH's Avatar
WRAH
Originally Posted by MillersG
Its important to note that these modifications rob and steal from each other! Combinations of these will yield results but I have not seen results even close to vendor/manufacturer claims for each part individually.
not true man! When adding mods you add the hp
this+this+this=great gains!!!
Old May 16, 2005 | 10:41 PM
papagz's Avatar
ricer mathhh....i wish you could get that much Hp. not possible. id say youd get about 25hp with all that stuff. we would all have very fast cars if they worked that way. if we had turbo cars from the factory, then it woudl be a different story. someone from 350zmotoring with an Sti slapped on an intake only and dyno's showed 12hp gains. INSANITY
Old May 16, 2005 | 11:07 PM
limeg35's Avatar
Here are dyno numbers of the some bolt-on, judge for yourselfs,.....dyno numbers
