My Coupe Service Engine Light Went On
Old Jun 4, 2003 | 10:09 AM
Kilrmy's Avatar
My service engine light popped on last night and I have no idea why it did. I am thinking it could be one of two things that happened but I do not know if they are serious enought o be concerned or to bring it to Infiniti to have it serviced. I cleaned my intake last night and moved it around a little bit, nothing too much but I don't kow if that did the trick. The second possibility is that I left the hood open for a while, while it was raining and I do not know if that may have done it. I unplugged the battery but that did not reset the light. The car is running fine and feels normal. Should I bring it to Infiniti to have it serviced? Will the intake void my warranty and therefore cost me an arm and a leg to have looked at? Will the light go off by itself and make me feel a whole lot better? The light has been on steady for about 16 hours now. Any thoughts are appreciated.
Old Jun 4, 2003 | 11:00 AM
dave_c's Avatar
Re: My Coupe Service Engine Light Went On
Call the service manager at your dealership.
Q Order, VIN issued, somewhere at sea
Coupe 6MT
Laser Red
Old Jun 4, 2003 | 11:14 AM
99atlantic's Avatar
they can refuse to serve you because of you intake (yea, as lame as it sounds)
since it's running fine i don't think you broke any of the air sensors, so I would say unplug the battery, but leave it unplugged for 12hrs. to completely clear the memory. It should only need like 2-3hrs. but better air on the side of caution
www.ironpumping.com
^^Bodybuilding Made Simple
Old Jun 4, 2003 | 02:31 PM
RamboRami's Avatar
G35driver.com Moderator
also check your gas cap, remove it and then twist it back on for 3 clicks minimum
G35c 6MT DG/Willow
newg37
Jul 26, 2015 09:32 AM
ClwMike
Jul 23, 2015 12:55 PM
igking
Jul 19, 2015 01:12 AM
mjfenix
Jul 17, 2015 02:07 PM
Jadenkid22
Jul 14, 2015 12:33 AM
