gear grinding for 05 AT???
Old May 23, 2005 | 10:04 AM
JDM 350GT's Avatar
its been a month since i got my AT G
it has 750 miles right now and recently i heard gear grinding (twice)
i put mine in garage and i dont drive it right away.
i wait about 2~3 minutes after i turn it on. (RPM around 1)
so i back up from my garage and i shift my gear from reverse to drive then...as soon as i step on the gas (gradually), it makes this (grinding?) sound for a second or two
anyone has any idea?
Old May 23, 2005 | 10:25 AM
SilverII's Avatar
does it happen only on cold starts?
Old May 23, 2005 | 10:54 AM
EZZ's Avatar
EZZ
This is the ABS self check that occurs every time you go past 5 mph. You probably don't hear it every morning due to radio, not paying attention, etc... but it does occur. Check the owners manual
Old May 23, 2005 | 11:20 AM
g8tor20's Avatar
FGC's official flip flopper
I posted this a while ago when I got my 05...here is the thread and the response...
https://g35driver.com/forums/g35-coupe-v35-2003-07/41365-weird-grinding-noise-after-cold-start.html
It still happens but I can only assume its normal.
Old May 23, 2005 | 01:16 PM
Msedanman's Avatar
O.F. Administrator
It's the ABS/VDC doing it's self test. Happens every morning first thing after starting and driving off at about 5 mph. normal
C.
Old May 25, 2005 | 11:34 PM
JDM 350GT's Avatar
thanks thanks XD
Old May 26, 2005 | 06:42 PM
xasnxkiddox's Avatar
Mine, I can feel something grind in the front when I step on the brakes after I start out slowly. Note that this is after pulling out from a 45 or 90 degree angle space. The grind doesn't feel good either and I can hear it pretty loud in the cabin. Is this also the ABS/VDC self checking? I don't feel/hear this everytime, just once in a while so I haven't brought it to the dealer to check because most likely the problem won't show itself.
Old May 26, 2005 | 08:15 PM
prelude555's Avatar
^^ i have the same problem, i can hear/feel a grinding near the front brake. it started when the car had around 200 miles on it and i waited out till it hit around 3k miles so i can bring the car for first oil change. i ask the tech to check it out and they dusted off the brakes and told me not to worry, the brake pads arnt worn evenly because on the 05 they use a certrain heavy duty brake pad that takes a while to wear them down. he said to drive it a few days to see how it goes n if the problem still there bring it back. are they bsing me ? sounds like it cause after 2000+ miles of driving the pad imo should be warn pretty evenly already unless the pads they claim is that strong. im giving them a month , back to the dealer it is
Old May 26, 2005 | 08:18 PM
JDM 350GT's Avatar
i have same problem but its minor.
my car has 800 miles right now and its been lil over 1 month
so far i heard that sound twice.
IMO, its something that you can never fix.
Old May 27, 2005 | 03:10 AM
decoy's Avatar
i'm at 48000 kms (divide by 1.6 to convert to miles) and it still does it
magnetism80
Feb 1, 2019 10:00 AM
RichardP9
Drivetrain
Oct 26, 2015 11:25 PM
alinero718
Sep 27, 2015 09:35 PM
Since 1983
Sep 19, 2015 10:26 AM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
