VDC, SLIP, SES lights on?
Old May 25, 2005 | 03:57 PM
G3NIU5's Avatar
during one start, they all came on steady. shutoff the engine, waited, turned it on again. now only the SES light stays on, VDC and SLIP are off. it's not the fuel cap, i've re-opened and close it and ive used up half of the tank already since i last pumped it so the cap hasnt' been touched for several days now.
will be bringing it to the dealer tomm, just wanted to know if anyone had the same issues? thanks.
Old May 26, 2005 | 01:21 AM
Jetleaf's Avatar
I had the same thing happen. My G only had 500 miles on it. I drove it all day went home took a shower to go out that night. Started the car and noticed vdc, slip, abs lights were on. After backing out of the driveway and starting on my way I noticed the speedo was not working nor was the odometer incrementing. SES light came on a little while later. The car ran fine otherwise. Next morning everything was normal except ses light. It happened again after only a few short miles. Took it back to the dealer and they had to replace the TCM module due to CAN communication error codes. That was 600 miles ago and so far so good. I hope this helps, peace.
05 DG 6MT OEM lip, spoiler
Coming soon 20" super rozzas and replacement of the Blose
Old May 26, 2005 | 01:24 AM
DanielEshaghian's Avatar
Looks like someones gonna need to take a trip to the dealership...
Old May 26, 2005 | 05:46 PM
areddy14's Avatar
same thing happened to me, i took it to the dealership and they took care of it in 5 mins. i think they had to check the fluids or something.
Old May 26, 2005 | 09:00 PM
weslutes's Avatar
Yes.... I remember mine doing that also. I fixed the problem by topping off my brake fluid. It seems that when your brake fluid is low,your VDC checks the lines and finds a problem. Then it turns all the lights on.
Old May 27, 2005 | 08:48 AM
Draco24433's Avatar
I had the same problem and it was a bad brake sensor. it was replaced under waranty and no problems ever since. Also check out the TSB forum. I know that one came out for that specific problem. Be advised, for me anyways when the lights were on neither my abs, vdc worked. So please be very careful especially during the rain. Good luck
Old May 27, 2005 | 11:39 AM
G3NIU5's Avatar
dealer called back. the problem was the throttle position sensor was malfunctioning. said they didnt have a part today, maybe next week, they'll call me back. i could get the car and drive it and would have no problems. they reset the ses light and checked everything, all was fine. hmm...
Old May 31, 2005 | 01:27 PM
Jetleaf's Avatar
Hasanbaloch
Feb 29, 2024 08:45 PM
Mry
Mar 3, 2023 01:03 AM
03sedang35
Aug 29, 2015 07:56 PM
Wayne9011
Aug 17, 2015 01:24 AM
Wayne9011
Jul 27, 2015 11:25 AM
