Q for those w/ 6 speed
Old Jun 17, 2005 | 12:55 PM
vipv35's Avatar
im learning how to drive a stick on this car and im starting to get the hang of it. one of my friends drove my car and said it was tough to drive but with time i will be all right. you should too.
Old Jun 17, 2005 | 02:20 PM
Ikazuchi's Avatar
I had an 02 rsx type-s,and the g's clutch is alot stiffer.It's hard to beat the clutch's on those honda's,they're way smooth.After getting use to your new g you will end up liking it very much!
Old Jun 17, 2005 | 02:40 PM
kenchan's Avatar
The hardest part was geting the shifter into the 2nd gate without the gearbox
getting notchy. It's got a very small window to get that timed correctly.
clutch engagement hasn't bothered me. overall it's an easier car to drive but
that 1-2 lever noticiness could be improved...
Old Jun 17, 2005 | 02:57 PM
Hockeyplay95's Avatar
Originally Posted by G35Vision
hard for 16 year olds ..... You will be fine .... after an hour, you will get it ..Good Luck
hey bud...I'm 16 and I have the 04' 6MT mastered -- I'm an expert
Hockeyplay95
Old Jun 17, 2005 | 04:01 PM
Amp's Avatar
Amp
Add me to the group who went from Prelude to G35. For me it didn't take long to adjust and the difference doesn't seem to be that great. The biggest adjustment to me is getting used to all the vibration you feel through the cluth when you shift at anything over 4500rpm.
Old Jun 17, 2005 | 04:05 PM
TheGest's Avatar
Gangster Member
ya same with me, i like the prelude shifting much more, feels more solid
Old Jun 17, 2005 | 04:08 PM
JAMN05G's Avatar
Echoing what all the other guys have said here, it just takes a matter of getting use to. I spent the last 4 years driving a 01 Cobra and the first time i drove my G i stalled it twice. It's now been 4 months since i've had my car and i am happy to say i love the way it drives.
Old Jun 17, 2005 | 05:14 PM
jayco's Avatar
at first i thought the clutch was a little stiff, but i've gotten used to it. i drove my buddy's 02 mustang GT and DAMN that clutch was STIFF, but it had a much shorter throw than my coupe.
Old Jun 17, 2005 | 05:29 PM
Memphis's Avatar
I like the clutch feel in my G35 C much better than the clutch in my 911. Part of the difference is that the Porsche's pedals are hinged on the floor which affects the arc over which they travel when pressed. It is something that takes getting used to when driving the Porsche.
Old Jun 17, 2005 | 06:59 PM
BlackG35th's Avatar
The clutch engages a lil high.... takes some getting used to... it'll be a few thousand miles till i start driving it like and auto but ill get it... b4 the the G, i drove a celica saturn and bmw3 seri and the G is by FARRR the hardest but then again the other cars arent hard to drive especially the saturn.... i stalled out like 5 days ago... kinda embarrassing buh wudda gona do... guess it happens o btw it was a hill so i guess its not too bad... dose anyone else occasionally stall, miss gears, grind or anything like that?
Old Jun 17, 2005 | 07:06 PM
Luke enas's Avatar
I had a rsx s with a stage 2 clutch on it. When I test drove the G It felt fairly similar to that. the dealer guy was a little suprised i didnt **** up. I though it was great
Old Jun 17, 2005 | 07:12 PM
Andy2434's Avatar
Yes, the clutch does engage quite high. It engages almost at the end of its' travel. My last 3 cars were BMW's, which were much easier to drive in MT.
I noticed that my brothers '04 6MT Sedan is much easier to drive. The clutch engagement point is about mid way and when the clutch engages . . . you really feel it and know it.
Has anyone else driven a '04 6MT and noticed the same? I was told that the '05 6MT's have a dual mass flywheel. Does that make that much of a difference?
Old Jun 17, 2005 | 08:12 PM
Finiti35's Avatar
FGC South Florida BOD
The 05 has a different pressure plate which affects clutch stiffness, don't know how exactly the dual mass flywheel affects clutch engagement. I admit that the only manual cars I've driven since I learned stick are a 350z, '04 G coupe and my '05. So I have NO idea how easy or hard any other manual car on earth is to drive, but IMO the 05 is actually easier to drive. To me the stiffer clutch makes the Z and '04 G a little harder even though like you pointed out you can feel exactly where the clutch engages, pre-'05s also require a greater shifting effort, but it's nothing all that different. I guess it's just a matter of what you're used to.
Old Jun 17, 2005 | 08:27 PM
  #30
vipv35's Avatar
it does engage rather high and for me to learn on it is pretty crazy. i gotta go to the dealership and check my tranny out tho cuz now that ive got the hang of it, im starting to hear an clunk when i shift.anyone know what it might be?
