What makes the difference in HP between MT and AT
Old Jun 22, 2005 | 02:18 PM
KuRuPT's Avatar
I was curious what parts make the difference in HP between the MT and AT. I heard someone comment that it was the spacer in MT that gave it those gains so I was wondering if this is true and what other parts make this difference. Thanks
Old Jun 22, 2005 | 03:29 PM
BlackonBlackG35's Avatar
I believe it has a higher red line too. So you gain more HP in the higer RPM's
Old Jun 22, 2005 | 03:42 PM
Deang35c6's Avatar
Intake runners (bottom plenum), ECU, VVT on both exhaust and intake sides. Some say even the rods and crank are different. This is coming from the 300 hp 350z, which should be the same engine as in the '05 6mt G35c.
Old Dec 29, 2005 | 02:15 PM
Slick 6MT's Avatar
BUMP
Does anyone have definitive evidence of the difference between the two motors?
Old Dec 29, 2005 | 02:21 PM
arjunz's Avatar
Bottom plenum is different.... ECU is different .... different Gear ratios? ...there really isn't much of a performance difference...
Old Dec 29, 2005 | 02:29 PM
MikeyMike's Avatar
Rollin On Dubz
Everything you guys said...
Plus...
Don't automatic transmissions lose 15% of power due to the Torque Converter not being as efficient as the Manual Tranny?
Old Dec 29, 2005 | 02:48 PM
Speedoholic's Avatar
G (enie) FUNK ERA
DING DING DING !
Correct. The torque converter is where most of the difference is. While stick cars have a direct and continuous connection between the engine and the wheels (vie clutch plates), the AT trannys are built as two turbine-shaped plates with fluid running in them. the loss of power is right there where it takes some massive force to spin the wheels-side plate using the turbulence cause in the fluid by the engine-side plate.
Old Dec 29, 2005 | 02:53 PM
z1n's Avatar
z1n
I believe it has different cams and valves as well. Think I read it in a 350z Brochure.
Old Dec 29, 2005 | 06:52 PM
RBull's Avatar
Rated M
Plus...
Your point is true of course there is even a little lower hp due to the AT.
It's not a factor in what is being compared- the crankcase horsepower of mt (298)vs. AT (280) The wheel hp of course is less and factors in drive train losses too.
Old Dec 29, 2005 | 07:33 PM
arjunz's Avatar
Hey, tell me one thing then .. i've raced a couple of MT's... and i have an AT.... and it seems like .... end of my 3rd and the whole of 4th gear i start pulling on them ... and they aren't bad drivers... whats the reason for that?
Old Jul 15, 2020 | 07:15 PM
Scottwax's Avatar
5 Year Member
6 speed G35 sedan
They're so far ahead they let off.
Yes, I know it is an old thread but I just couldn't resist.
Old Jul 15, 2020 | 09:47 PM
G2B35AGN's Avatar
A worthy revival for a perfect riposte. It's sort of like thinking of the perfect comeback after the party's over and you're on the way home....
Old Jul 15, 2020 | 10:05 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Not to get too technical but a direct comparison between the two types of transmissions is pretty much even on the quarter mile. The difference is found on a road course track where you're able to grab gears with better precision, decel, turn the car with the gas pedal, etc.
A 240whp car isn't going to see a very big margin of difference comparing either power train.
Frankieg35
Mar 20, 2016 09:42 PM
wonderizm
Sep 24, 2015 03:09 AM
Frostbite91
Aug 12, 2015 05:16 PM
