mushy brembos on cold start?
Old Jul 7, 2005 | 08:13 PM
weaksauce's Avatar
i have an 04 with only 7K miles and brembos (6mt). i have noticed that when i first start driving, the brake pedal seems mushy. with even pressure, the brake pedal modulates (shakes?) under my foot before braking. (i know braking inst a word, its sounds so very jdm tho for some reason..."brembo make for happy braking in sad weather situations...")
i digress tho. after the 1st or second stopping, it seems to go away. anyone have the same issue? i have also noticed that it rains here ALOT and the rotors look like they are rusty brown 1st thing in the morning. after using the brakes tho, it looks like they clean off.
is this normal or should i take it to dealer? is it just the moisture here?
i havent noticed this on my last car and this is the 1st time i have had brembos since i have moved here (georgia). am i being too sensitive or is this an acutal issue?
Old Jul 7, 2005 | 09:32 PM
Jiwon's Avatar
Carbon Ceramic brakes will solve all the problems
Although $$$
Old Jul 7, 2005 | 09:35 PM
gspotter's Avatar
Haven't noticed any problems with mine (8500 miles).
The rust is normal.
Old Jul 7, 2005 | 09:38 PM
Jiwon's Avatar
The rust is normal.
Is that really rust ? I thought it was dust.
Try to wipe it with your finger, it doesn't seem like rust
Old Jul 7, 2005 | 09:43 PM
Msedanman's Avatar
O.F. Administrator
The rust he mentioned is on the rotor itself, not the wheel. It's normal for them to surface rust in moist conditions, and to wipe clean again on braking.
C.
Old Jul 7, 2005 | 10:39 PM
weaksauce's Avatar
C.
sorry, jsut read the comment again. the dust i usually see and am used to is just brown on the rotor. this stuff is red brown. not dark like on the wheels. it is literally more red then brown. i havent seen dust this color, so i am a bit worried. if you guys say it is just dust, then ill prolly stop keeping myself up at nights about it
Old Jul 8, 2005 | 12:23 AM
TimW's Avatar
if you have a small leak, ya better get that off the wheels, it will ruin the finish. Redish brown sounds like fluid to me. It will look like a mist if it leaks while the car is moving.
Old Jul 8, 2005 | 10:49 AM
G3NIU5's Avatar
he mentioned about the rain, so that's rust on your rotors, normal. all metal rotors do that. and if you leave the e-brake on overnight, next morning you'll feel a light thud when you move, those are the rear pads that got stuck on the wet rotors.
the brake modulation might be the ABS working.
Frankieg35
Mar 20, 2016 09:42 PM
andyg35c1
Aug 29, 2015 03:37 PM
sinasajadi
Aug 26, 2015 04:12 AM
NemesisGee
Aug 11, 2015 07:10 PM
Karnicle
Jul 23, 2015 05:08 AM
