problems with the bat
Originally Posted by pdjafari
Gman I see what your saying, however at the same time BATs record/history gives him the advantage if you can call it that. So many members have bought things in the past w/o frequent problems therefore credibility goes to BAT. Now if the member who complained was very well known on the boards etc, that may change things a bit or if this type of issue persisted with other members.
Now I am not going to give this sponser's name cause I don't want to start another thread like this, and I am not implying that Bat made this same mistake, but just because someone has a great reputation does not mean they don't *** up and then try to blame it on someone else.
Gman, I see what your saying. I already know which sponsor your referring to
!! Only one I know of that uses DHL and I actually just ordered a lip from them. In a way theres always some bad experiences. The vendor your referring to also messed up an order for one of my friends on the boards as well (sent the wrong color OEM lip and took about 4 weeks to get the right one!!) Hopefully it'll be delivered by the date promised!!
no i respect the fact he didnt come out and say it like you did...
Gman, howz the Greddy TT treating you?!?!
Thats awesome!! What made you decide to go w/ the HKS over say the eManage or other ECU systems?? That Vpro is an engine management/piggy back system right??? What features does it have that the Greddy system does not?!?
The HKS Vpro is a full standalone unlike the emanage that is a piggyback. Since piggybacks only influence the ECU and not control it, I decided to go full standalone. I have too much $$ invested and I am affraid the ECU will spontaneously add timing or somthing and kaboom! After the HKS Vpro the ECU will not handle any motor functions except for the Drive by wire, VDC, and cruise control, and non motor functions. Also with the A/F Knock amp it can auto tune the system for a set A/F ratio. In other words the system will make whatever adjustments it needs to always maintain the A/F ratio I set it for.
