anyone knows installation front chin spoiler and splash guards?
Old Jul 18, 2005 | 01:21 PM
sean77's Avatar
i am thinking get front chin spoiler, front splash, and real splash guard from everyingG35.com.
those i really wanted, and finally i decided
but i want to install by myself otherwise i have to pay for it to dealer...
so does anyone know installation or some guides if you have let me know..
thanks for reading guys!
Old Jul 18, 2005 | 01:27 PM
madchef's Avatar
Have you checked the FAQ/DIY section? The splash guards I know comes with instructions (pretty straight foreward anyways)
If not there, then I'm sure a search will turn something up
Old Jul 18, 2005 | 01:30 PM
JReedG35C's Avatar
If you're willing and have a drill you can save that installation cash for something else like a CAI. It's easy...I did my own splashguards and front lip. It only takes a few hours of your time. Mine came out great. Just follow the instructions that come in the box and you'll be fine.
Old Jul 18, 2005 | 01:34 PM
Speedoholic's Avatar
G (enie) FUNK ERA
If they ship you the front chin spoiler in its original box (as I would assume) it will include instruction. Very easy, and definitely not something you want to pay your dealer to do.
Same goes for the splash guards - as long as all the original material is there, you should be fine.
Old Jul 18, 2005 | 02:07 PM
sean77's Avatar
Smile thanks for great answer guys!
by the way, do i really need a drill work...
if i need what kind of drill size, do i have to buy?
thanks
Old Jul 18, 2005 | 02:13 PM
6-Sigma G35's Avatar
It's a cake-walk!
The installation is pretty simple. I recommend that you have a good jack (i.e., NOT the scissor jack) and jack stands.
The splash guards take the least effort and time, IMO. Also, I didn't predrill the holes, I just drilled the screws after I removed the double sided sticky tape and put them on the car. I DO recommend that you get a good feel for HOW the splash guards fit on. Meaning, place and remove the splash guards on the car without removing the tape back-this will help, trust me. If you don't get the rear ones placed right, the rear piece will pop away from the car (it happened to me....I had to buy more double sided sticky tape).
The front chin spoiler....well, if I followed the directions and used the template, it would have been a complete PITA. After messing with the paper template/guide for 15 minutes trying to get it aligned, I gave up and just 'winged' in.
Essentially, I started at the ends and worked my way to the center of the spoiler. Just make sure you get that thing thing fitting snug to the bottom of the bumper to ensure it's even. It wasn't that hard, but at first, I was scared that I would screw up.
Oh.....make sure you wash your car. In and around the areas where the double sided sticky tape would make contact, I used a 50/50 H2O rubbing alcohol mix to wash away the wax and crud. I suppose you could use normal dish soap, but opted for the rubbing alcohol.
GOOD LUCK!
Old Jul 18, 2005 | 02:17 PM
sean77's Avatar
thnaks 6 -sigma and other people
Old Jul 18, 2005 | 02:20 PM
G (enie) FUNK ERA
thanks
All the drill bit sizes are specified in the installation instructions accompanying both the lip and the guards. I strongly recommend you to follow these sizes.
Old Jul 18, 2005 | 04:56 PM
G35UKY's Avatar
GOOD LUCK!
For the chin spoiler, I started in the middle and worked my way out to each side, and I did use the paper templates. The templates were a pain in the @ss, but I still think it was easier than not having them if you just tape them in place. Also, be sure not to over-tighten the two center screws because it will cause slight dimples in the spoiler that you can see if you are at the right angle. It mentioned this in the instructions, but I didn't understand what the "Japanglish" was trying to say until I already had everything done and cleaned up . I still need to fix that, but no one notices except me. PM me if you have any questions.
Old Jul 18, 2005 | 06:42 PM
sean77's Avatar
thank you very much everyone! i am so happy you guys so nice people!!
jsimonk
Dec 22, 2023 03:49 PM
st33zygill
Jul 29, 2015 10:05 PM
laksjd84
Jul 24, 2015 05:12 PM
vstypicals
Jul 20, 2015 10:55 PM
