Brake cooling ducts?
Old Jul 27, 2005 | 03:57 PM
madchef's Avatar
Question Brake cooling ducts?
I know I've seen them on a coupe before, but a search turns up nothing.
Has anyone here made use of our stock front bumpers and put in some brake cooling ducts? I would really like to do this mod, so pics would be awesome...thanks!
Also, how did you do it? Did you run underneath, or drill through?
Old Jul 28, 2005 | 12:46 PM
madchef's Avatar
bump
Old Jul 28, 2005 | 06:49 PM
baileyrx's Avatar
this will work but you need to decide where the air will blow into the wheel. Possibly right at the caliper!
Attached Thumbnails Brake cooling ducts?-2004_0404soll2a01123560zb.jpg   Brake cooling ducts?-2004_0404soll2aairduct.jpg
Old Jul 28, 2005 | 06:54 PM
baileyrx's Avatar
closer look
Old Jul 29, 2005 | 11:29 AM
madchef's Avatar
Very cool, thanks!
What kind of cutting/drilling/etc did you have to do for that setup?
Old Jul 29, 2005 | 12:09 PM
baileyrx's Avatar
You'll need to remove some gray foam from behind the bumper cover & then cut a hole in the plastic wheelwell liner. I used black zip ties to hold the duct in place. Be careful where you direct the air flow. You'll want to avoid the rotor itself. Since you can't "hit" both sides of the rotor with the air flow, to get even cooling. You'll end up warping the rotor. When the inside cools faster than the outside. That's why I'd reccommend the caliper itself. Try and get the air flow going over the top & around the whloe thing. Race cars will just direct the air flow wherever they need it, but then they simply replace parts at the end of the race.
I bought the clear plastic duct on eBay($12) & bought dryer duct from Home Depot. Painted it flat black.
Old Jul 29, 2005 | 01:55 PM
madchef's Avatar
Nice, I was worried there would be something other than foam I would have to cut through (besides the wheel well liner of course)
And thanks for the tips, guess I hadn't considered the "one side cooling faster" problem
Old Jul 29, 2005 | 05:47 PM
636Racer's Avatar
nice NACA ducts. where'd you get them?
Old Jul 30, 2005 | 01:38 AM
ZeroGen's Avatar
Omega Enthusiast
Planning on doing some serious braking?
That gray styrofoam you removed is part of your bumper - shock absorption.
Old Jul 30, 2005 | 02:31 PM
madchef's Avatar
Yup...track
Old Jul 30, 2005 | 07:38 PM
baileyrx's Avatar
i bought them on eBay about a year ago. pretty cheap ~ $10 i think
xx7sephiroth7xx
Brakes
May 3, 2023 07:07 PM
tadmcmichael
Brakes
Oct 18, 2015 01:47 PM
mattdg35
Sep 14, 2015 11:28 AM
Hawk196
Sep 10, 2015 10:37 AM
NJ6MT
Sep 10, 2015 08:40 AM
