800 miles with service engine soon light?
Old Aug 11, 2005 | 09:05 PM
mc2's Avatar
mc2
So i'm supposed to be driving to vegas tomorrow from LA. Just today my MIL came on, it is a steady light, not blinking. From reading the manual, i am under the impression that it's not serious. Do you think i could get away with driving to vegas and back with this light on?
I have an appointment for the dealer first thing tomorrow, but i do need to leave around 2 o clock. I imagine they'll pull the codes and in the event that they will need to keep the car longer than past 2PM i am hoping that whatever it is can wait until i come back from vegas.
What do you guys think? What are the possibilities for a solid MIL? I've already checked the gas cap.
The car is a 05 6MT with 5000 miles on it.
Old Aug 11, 2005 | 09:09 PM
Hooman6MT's Avatar
20 Year Member
I wouldn't worry too much about it. You could drive on it, shouldn't be any problems. Wait to see what codes they pull up. If it's an O2 sensor or something minor like that, go. If it's something like oil pump failure then don't. Just ask the SA and see what his opinion is. good luck in vegas. Make sure you turn your AC off every once in a while during your drive.
Hooman
Old Aug 11, 2005 | 09:14 PM
mc2's Avatar
mc2
Hooman
Thanks for the advice. Would the car overheat otherwise? And should i do this just because of the temps in vegas? Or because it's a 5 hour drive? I'll be driving mostly in the night so if it's because of the ambient temperatures that should not pose a problem.
Old Aug 11, 2005 | 09:16 PM
g35vixen's Avatar
From: LAS VEGAS [ a sunny place, for shady people ]
The same thing happend to me at about 1000 miles. Took it too infiniti and they said it came on from me filling the gas tank too full. So if you top off the gas to round the price that might have been the reason
Old Aug 11, 2005 | 09:35 PM
Hooman6MT's Avatar
20 Year Member
yea...don't be fooled by vegas nights. Nights can still be in the high 90's. Plus the drive has many uphills and downhills, this will cause the car to get too hot. I'm not worried too much of overheating, but it is a lot of stress on the car. Driving fast, AC blaring, etc can lead to problems. You'd rather take some load off every once in a while so the car can breathe.
Also check your tire pressure before the trip. Driving at high speeds and at high temps will cause the pressure in the tires to increase and cause a blowout. I was coming back from vegas once in a 350z (it has tire gauge on the display) and I started at 34psi when I started the car, and was at 40psi after 45 miles. I stopped at a gas station and lowered the pressure to 35psi. You might want to check your tire pressure before you leave and maybe take it down 2 or 3 psi, to compensate for the pressure.
Hooman
Old Aug 11, 2005 | 09:48 PM
SilverMtZion's Avatar
not tryin to hijack thread but anyone know if disconnecting the battery for extended periods of time will trigger this?
Old Aug 11, 2005 | 11:09 PM
Brian-g35's Avatar
just came back from vegas this weekend....drove with the a/c straight back and forth np at all... You're drivng at night so it should'nt be a problem have a safe trip..
Old Aug 14, 2005 | 03:11 PM
mephistomyhero's Avatar
Hey, it would be nice if us G owners had a tirepressure Gauge too. :-)
Old Aug 14, 2005 | 04:14 PM
Msedanman's Avatar
O.F. Administrator
Shouldn't cause it but may reset it.
C.
poktanG35
Engine - Exhaust
Oct 26, 2015 03:32 AM
newg37
Jul 26, 2015 09:32 AM
ClwMike
Jul 23, 2015 12:55 PM
igking
Jul 19, 2015 01:12 AM
mjfenix
Jul 17, 2015 02:07 PM
