High RPM gives tranny grind...
Old Sep 1, 2005 | 08:47 AM
yso8629's Avatar
Hi everyone,
I have a quick question on transmission.
I just hit 2000miles and done with break-in on my '05 coupe.
I pushed the car little over 4500RPM at 1st gear and pushed down clutch (all the way to the bottom) to shift gear to 2nd and there I felt something different than my normal drive.
I felt the clutch grind and engine/transmission sounded different (when I pushing down the clutch).
Is this normal?
Old Sep 1, 2005 | 11:19 AM
kenchan's Avatar
you felt the clutch grind?! throwout bearing?! never heard of that
Old Sep 2, 2005 | 05:06 AM
da45king's Avatar
its time for mobil 1 gear oil.......it will clear that right up....every other G on here has had the "1 crunch 2" syndrome....Mobil 1 gear oil
Old Sep 2, 2005 | 05:32 AM
GTT's Avatar
GTT
G35 Twin Turbo
if u have an 05 then this is normal as mine and you will feel more change when u shift at 6400 rpm, cause the clutch is different than the 03-04
Old Sep 2, 2005 | 05:35 AM
GTT's Avatar
GTT
G35 Twin Turbo
I was wondering why u still keep driving ur car slow. I pushed my car hard on my first time at 600mile and it was cool. Go out side and push ur car hard to know ur car more nothing gonna happen but drive carefully.
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
g.spot
May 9, 2016 10:54 PM
the93owner
Oct 4, 2015 09:40 AM
vamarris
Sep 26, 2015 12:56 PM
