DIY: LED Coupe Clear Corners
Originally Posted by PeteNJ
EK,
If you look at the wiring diagram on my DIY you will see that source voltage is actually around 14.4V. You need to get the proper resistors to prevent this current from burning out the LEDs. That site I pointed out has a neat LED array calculator which does all the work for you. BTW, I have some questions about your projector retro I will PM you about. Thanks
Originally Posted by E_K
Yeah, I saw the links. Thanks for posting them. But I didn't know what to input for current. I'm really horrible with electronics. I'm wondering what it would take to power up 12 LEDs in a single line with a 12V power source.
You can also do it in a simpler fashion by linking all the LEDs up parallel and using one resistor. However, I did this with my first design and it did not work correctly. The LEDs would shine at different light levels. However, other members have done it this way with success.
BTW, what are you trying to make?
If it is an automotive application it will be 14.4V not 12. The array calculator on that site will ask for source voltage so just input that, operating current, and number of LEDs in the array.
I'm trying to put some LEDs into my headlights. What's the operating current going to be? The power source is going to come from the signal clearance light.
Ok, I just figured that it was 12V, because the light bulb in the power source right now says 12V.
The clearance strip is made up of two pieces. There's an outer clear lens, and a chrome back half. There's a good amount of room there. I have 2 extra pairs of headlights, if you're willing, I could send you the clearance strip and pay you to put in the LEDs for me. I could also give you an extra pair of clearance strips in exchange.
Ray, I wish I could have a printed PCB for this project. It would have made life A LOT easier. If you have a source who could do this I would be very interested. All that copper wiring and solder is ghetto haha. My goal is to convert all the bulbs in this car into LED. I will send you a PM.
A PM has been sent to you.
![Smilie](https://g35driver.com/forums/images/smilies/smile.gif)
Regards,
Ray
I'd pay for a printed board and component kit. Hook me up!
My ideal setup would be two rows.... 1 row white for side marker and 2nd row to second lead that could be tied to blinker using vampire crimps. This way you blink yellow and ride white.
Please PM or announce as a new thread if you come out with PCB.
P
P
