With gas prices so high, I'm wondering how low is too low to rev while cruising?
Old Sep 13, 2005 | 04:15 PM
chilibowl's Avatar
If you guys are complaining about fuel economy, then the G is not for you. I wouldnt expect someone that drives a 35K+ car to complain about gas.
Old Sep 13, 2005 | 04:17 PM
Gee Im Fast's Avatar
I think its fair to complain about gas now that none of us have ever experienced these hikes before (unless you lived in the 60's/70's gas shortage crap)....its hard when you know how much you used to pay vs. now...
Old Sep 13, 2005 | 06:31 PM
mc2's Avatar
mc2
Why, just because you drive an expensive car means you should just throw money away?
Old Sep 13, 2005 | 07:31 PM
htownboy's Avatar
Originally Posted by mrjonang
26 MPG is pretty damn good, is this mostly highway driving? not as much street driving? Typically for me i get almost no freeway driving, always city driving. Being that is 13-15 MPG considered too low? I drive an 05 AT and shifts are usually no higher than 3000 RPM. Does this MPG fit in with my driving or does my car have problems?
Also since my car has been in the shop due to a rearend incident for 29 days, it has mostly been sitting still. Would this have affected my MPG in any way? My friend mentioned to me that my transmission oil has went bad since its just been sitting there for a month w/o any warmup driving. Before this incident i used to get 16MPG and up all with city driving. Is he right? or is my car just problematic.
*About 40% city driving during my commute.
*Yes, 13-15 seems low to me, i've never had MPG that low, not even on weekends playing around, driving hard, but my friends 5MT gets about the same as yours.
*Your car has no problems, for a 5MT your rpm's seem right to me, you really have to be crawling to get it to shift at a lower point, it the 6MT you have more low end torque so it seems effortless, no lugging etc; you can take it down pretty low as long as you don't foresee accellerating quickly for awhile. It's very easy to gain speed slowly, like in traffic, the car rolls so easily, you basicall are just keeping it rolling.
*The transmission question is a good one... The fluid used these days is much better than previous years and resists condensation, but some people will argue that; personally, I would change it, but I don't think it's a factor in the MPG's being lower.
I also would consider an ECU reset, this may help... I wonder if your battery was disconnected while the car sat up or if it drained down??? Keep this in mind, fuel will condensate too, so you may want to use a good additive to treat that, a month is not really a long time, but it's only a couple of dollars & can't hurt.
Old Sep 13, 2005 | 07:36 PM
htownboy's Avatar
Originally Posted by gto2050
I usually get 20-21.5 MPG and I tried last wee k to see how the driving method would affect mileage. I took off in second and shifted to 4th and then 6th. The result was an increase to 24.6 on just one tankful. I was running in 6th at 35MPH and I think the RPM was around 1100-1200 or so. I didn't shift much over 2000 at anytime. Now, will a clutch cost me more in the future? Possibly but I only did it for a week to see what would happen. Higher mileage is possible.
As long as you don't do those 2nd. gear take offs too often, the clutch will be fine... I use all 6 gears, just get through them quickly and im really happy with the MPG's.
Old Sep 13, 2005 | 07:40 PM
htownboy's Avatar
True, but I didn't read many complaints, just people wondering how to not waste fuel... It's no big deal, if my G got 10 MPG I would still be happy with it, but over 25 is really nice! When I want to play, I don't give a dang how much fuel is burnt.
Old Sep 13, 2005 | 07:44 PM
Andy2434's Avatar
There is nothing wrong with being frugal and attempting to save a few dollars. What does owning a 35K+ car, as you put it, have to do with the discussion? Most of these people have families and/or other financial obligations.
Old Sep 13, 2005 | 07:47 PM
htownboy's Avatar
Originally Posted by benster
when i shift under 2000 and often from standing still, toyota tercel's are passing me. if a big truck is behind me, they seem to get real close each time i shift and they remain accelerating. i know i'm saving gas but i personally do not want to be the slow car coming out of a red light. am i just that slow in shifting?
does that feeling of saving gas make you feel ok when car's pass you? being the slow car is too foreign and weird. anyone else's thoughts?
Dang, how long does it take you to go from one gear to another? I can keep up with most traffic just shifting around 2000; do cars on the side of you pull ahead between your shifts? You may be taking too long to get from gear to gear man, it should happen in the fraction of a second and be second nature for you to do it. Get a friend to check your shift lag time. Man I've been in cars where it has taken the driver 2 seconds to get from gear to gear, thats a shame!
Kz_Ed
19 Inch
Oct 16, 2015 10:32 PM
wojowojo16
Jul 27, 2015 09:57 AM
EasySausage
Jul 20, 2015 03:56 PM
CrazyLogic219
SouthEast
Jul 15, 2015 02:35 PM
