concerned about rev limiter
Old Sep 15, 2005 | 01:16 PM
dls160's Avatar
I own an 05 g35 coupe AT and what happened is that i accidently hit the shifter lever with my hand and it bumped it over into manual mode while i was in the process of getting on the throttle pretty hard. It then went to the rev limiter and i couldnt figure out why it wouldnt upshift until it had been at the rev limiter for about a full 3 seconds. I really dont drive my car hard and you could probably count on one hand the number of times that i have really got on the throttle. I am wondering do i have something to worry about or is my engine ok? I dont know much about the g35 engine, so can someone give me some feedback. i know what happened isnt necessarily good for the engine but do i have anything to worry about? like future problems or if i damaged anything. It sounds and runs fine but i still would like someone elses opinion. Thank you very much for any feedback.
Old Sep 15, 2005 | 01:35 PM
kenchan's Avatar
i don't think you can ever over-rev an AT car enough to damage the motor.
Old Sep 15, 2005 | 01:54 PM
RaleighNC's Avatar
Someone else will probably chime in, but I have hit the rev limiter a two times and it does sound Chitty but I don't think it should pose a problem for you.
Probably scared the crap out of you didn't it?
Old Sep 15, 2005 | 02:06 PM
Hutch's Avatar
I have done it a time or two also. Scared the s**t out of me. It doesnt take any time to get to redline when you stand on the gas.
Old Sep 15, 2005 | 02:11 PM
TINMAN's Avatar
you should be ok.don't worry about it.just don't do that on daily basic LOL.
Old Sep 15, 2005 | 02:28 PM
madchef's Avatar
Don't worry about hitting the rev limiter....it's there to make sure you don't go too far
Old Sep 15, 2005 | 02:32 PM
Hooman6MT's Avatar
20 Year Member
the rev limiter is a SW controled number. The ECU sets the limit to a range that is below what the engine can handle. This is why people have their rev limiter removed or moved up, because the engine can handle more.
Technically you can bouce off your limiter everyday and not have any problems. If you drive a MT car and improperly shift into 1st gear instead of say 5 then you'll Mechnically over-rev your car and blow your engine. This is commonly referred to as the "Money Shift" because it's going to cost you a lot of money for that 1 shift.
Hooman
Old Sep 15, 2005 | 02:35 PM
Gee Im Fast's Avatar
My "money shift" is when I downshift and pull on someones a$$!
Old Sep 15, 2005 | 09:41 PM
dls160's Avatar
yeah it scared the sh*t out of me. Ive only had the car for about 6 months and i thought that i had already F*cked up my car.
Old Sep 15, 2005 | 09:43 PM
dls160's Avatar
I greatly appreciate all of your inputs. Thanks. Maybe now i can forget about the whole thing.
Old Sep 15, 2005 | 10:31 PM
Andy77's Avatar
I'm sure everyone has hit the rev limit. I'm sure you won't hurt anything by doing that, especially if it is only occasionally. Enjoy the car!
Old Sep 15, 2005 | 10:41 PM
gettaluvr's Avatar
rev limit is there to protect, as long as you dont over rev due downshift, upshift wouldnt hurt but dont really suggest you do too often !!
Dallsinghjr1
Sep 17, 2023 11:25 AM
Marlin84
Apr 1, 2020 12:52 PM
mbe32
Nov 13, 2015 11:09 PM
vamarris
Sep 26, 2015 12:56 PM
