Help AT G35 keeps stalling!
Old Sep 25, 2005 | 03:30 AM
savefatkids's Avatar
put ur stock intake back on..if u still have the problem take it to the dealer..
Old Sep 25, 2005 | 11:15 AM
sdkingka's Avatar
i had that problem on 2 of my previous cars, both AT, of course. usually what happened was that, they were all over 100,000 mi, and whenever i brake pretty hard from going about 50~60mph the engine would die. ( it was toyota camry v6, and infiniti j30, btw) for some reason whenever my bro drove those cars, it would do that more, i think bc he accelerate too hard and brake too hard all the time. i took over the cars, drove slower, got tranny flush, and the problem eventually went away.
i was pretty sure that its tranny issue...
ive taken both cars to many many mechanics and they could never figure out what was really causing the cars to do that... what i recommend is tranny flush, and be nice to your car for a little while. its always a good idea to try not to give so much stress to your AT.
Old Sep 25, 2005 | 11:16 AM
sdkingka's Avatar
i am sure it has nothing to do with the intake. i have '03 AT with same intake, and other mods, but never had that problem.
Old Sep 25, 2005 | 12:38 PM
Ryffryda's Avatar
Idle at beginning of the day... 1100, then after its warm and going around 5-600ish I would say.
Old Sep 25, 2005 | 03:30 PM
Derek S's Avatar
i didnt have the same problem but i had one close to it, i had a pop charger with z tube and i was getting low idle as well and my car would acting funny i would hit the gas and the car wouldent go i changed it back to stock and its been fine ever since after looking at my MAF sensor i saw all this oil bild up on it, i didnt want to mess with it and clean it since its working fine but if i get it again im ganan clean it.
Old Sep 25, 2005 | 04:10 PM
OOOOA3's Avatar
Alumni****
i would put back my stock intake and bring it to the dealer to have everything checked out.. just tell them the symptoms.. they'll probably recommend a tranny flush just like what somebody already said.. but yeah, i'm guessing it's the MAF as well.. but i've never experienced or heard of this problem with the injen intake on an AT G.. good luck..
Old Sep 25, 2005 | 05:35 PM
Msedanman's Avatar
O.F. Administrator
Originally Posted by GonSpeed
the injen is whats stallling you...
If they determine that the Injen is what is causing the stalling (and it could very well be the cause), then the dealer will charge you for analyzing and determining the cause.
First check the connections and hoses for leakage and loose clamps. If they're fine check the inlet for obstruction and blockage.
If they are fine, you may want to take off the Injen to see if that's the cause first and then go from there.
Your symptoms indicate a dirty MAF sensor, or a leak/blockage somewhere in the intake system, and not necessarily the Injen (but most likely).
G/L
C.
Old Sep 25, 2005 | 09:58 PM
][ron|2icE's Avatar
Originally Posted by Atooraya
ummmm, maybe you suck at driving stick?
reverse needs a bit more gas to keep going than 1st gear does, and don't let your rpm drop below 1500 rpm and you should be fine
Ummm maybe you suck at reading threads. He says it's an AT pfffttt.
Anyways, most likely your CAI like everyone says. If it is your CAI it's not covered under warranty which sucks.
Old Jul 22, 2007 | 10:54 PM
eyecbatty's Avatar
what became of this problem..did you fix it?..cause its happening to me now..
Old Jul 23, 2007 | 01:19 AM
mephistomyhero's Avatar
Raising this thread from the dead huh?
Now, if you read through this thread and another one, you'll noticed almost all the same trend: They have an after market CAI. I can't say for sure, but I would say 90% of them have it. So, if you have one, remove it and see what happens. I amazes me how many times I see these threads and when we find out they have an after market CAI, they are so reluctant to take it off and put back the OEM and will do everything but put back the OEM. Well, it's only an observation.
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
Wayne9011
Aug 17, 2015 01:24 AM
VANST3R
Lights
Jul 27, 2015 08:20 PM
Wayne9011
Jul 27, 2015 11:25 AM
laksjd84
Jul 24, 2015 05:12 PM
