Tire Pressure Alert (temp drop?)
Old Oct 19, 2005 | 07:49 PM
shipsaeki's Avatar
temp changes will deff effect your tire pres.
I get them all day long now that it's getting colder out. you guys/girls should set your tire pres. to around 36-38 depending on your area and ride comfort. The TPS will come on when the psi reaches 26-28 lbs of air. so setting it around 36-38 will reduce chances of that annoying light and beep.
Old Oct 19, 2005 | 09:05 PM
04G_CAR's Avatar
Originally Posted by kidtronix
LOL ME2...I thought something was wrong with my stereo at first. Good to have the alert though, especially with the 19's. Don't want to biff another rim!
Ditto. I know it's going to happen, but everytime it does I start looking around the car for something burning...
Old Oct 20, 2005 | 11:47 AM
Atooraya's Avatar
what's the best PSI then?
36-38?
i got the car when it was in the 90's, and now it's in the 50's and nothing has changed
Old Oct 20, 2005 | 12:00 PM
cup0spam's Avatar
ditto... I have about 5000 miles on my ride, never seen the pressure sensor go off yet. Hopefully they work The tires look perfectly inflated, but it is starting to get cold in the nights/mornings, i'm sure i'll see some activity from them soon.
Old Oct 20, 2005 | 12:15 PM
Wayno_san's Avatar
20 Year Member
The tire pressure alarm went off last weekend. It scared me also since I've never seen it engage before. I was paranoid that one of the tires was leaking but after stopping a couple of times and not noticing any difference between the four (it's hard to tell with the low profile 19" tires) I figured it must have been due to the temp drop. I pulled over at a gas station later that evening and they were all at 32psi. I went up to around 37 on all four.
-Wayno-san
Old Oct 20, 2005 | 12:17 PM
SilverII's Avatar
Just a friendly reminder that if your PSI is too high, you might see increased center wear!!!
Old Oct 20, 2005 | 04:18 PM
Msedanman's Avatar
O.F. Administrator
I agree, and from what I know, optimum performance is realized at the manufacturere's recommended pressures.
One or 2 psi above the recommended pressures should be ok.
It's wise to keep an eye on tires regularly, due to big fluctuations in pressures due to ambient temp changes.
C.
Old Oct 20, 2005 | 05:44 PM
visualfusion's Avatar
I set mine at 34 all around... and I think the OEM 19" rims + tires setup recommends 35psi... just a little bit lower for the hotness of the california afternoon =)
Old Oct 20, 2005 | 08:24 PM
sngpimpin's Avatar
lol, that was me this morning too. i was totally on the way to school at 730am and all of a sudden this beep scared the begezzes out of me...i was like wtf. but yah tire pressure happened to me today.
jsimonk
Dec 22, 2023 03:49 PM
Kng0fHrts
Sep 15, 2015 05:40 PM
Jnm07
Aug 6, 2015 03:03 AM
joedaddy1
Jul 28, 2015 02:58 PM
