Help: ABS, SLIP, VDC question
Old Oct 22, 2005 | 01:23 AM
Silverbullet35's Avatar
When these lights stay on, I know most of the time its brake fluid/pad related, but is there anything else that would cause these to stay on? My pads and fluid are fine. Could it be a fuse? Any help is appreciated. Thanks.
Old Oct 22, 2005 | 01:29 AM
Msedanman's Avatar
O.F. Administrator
......another cause is a faulty brake pedal switch......and there is a TSB on this condition.
Dealer time...
C.
Old Oct 22, 2005 | 01:37 AM
gfx35's's Avatar
I have the same situation,started after the exhaust and cats were installed!
Mine comes on after 20mins. or so.
Old Oct 22, 2005 | 10:18 AM
I hate bringing my car to the dealer b/c my car is far from stock. I just drilled a hole through the firewall and ran some lines to the battery, then when I started it up I noticed these lights were on. I'm pretty sure I didnt hit or damage anything, however I had the panel with the VDC button off and I am thinking it may have something to do with the brake light switch harness. (I did have the TSB done). I guess I'm just gonna check the fuses over and recheck the brake fluid level. Any other reccomendations?
Old Nov 26, 2005 | 12:13 PM
superchargedg's Avatar
take back to dealer if its 03 or 04 for the brake switch interlock control. that fixed my lights.
Hasanbaloch
Feb 29, 2024 08:45 PM
Mry
Mar 3, 2023 01:03 AM
Wayne9011
Aug 17, 2015 01:24 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Wayne9011
Jul 27, 2015 11:25 AM
