Sunroof rattle not the same as sunroof squeek
Old Oct 28, 2005 | 05:59 PM
JoeyG35's Avatar
Arrow Sunroof rattle not the same as sunroof squeek
Hi all,
I have a '04 coupe and I've been getting this annoying rattling noise lately, coming from the sunroof area.
I know there are plenty of other threads about sunroof rattles, but they all seem to point to the "sunroof squeek" TSB. I have performed this TSB, and it did not cure the rattling noise. However, the rubber trim around my sunroof no longer squeeks when I leave my driveway.
The rattling I'm experiencing happens still, even with the sunroof open. It's harder to hear due to the wind noise, but it's still there. I can't seem to localize it to a specific point, but it's near/around the roof guide-rail and cabin light area.
Anyone else experience this?
Old Oct 28, 2005 | 08:12 PM
TimW's Avatar
you have to pull down the headliner (just the front corner, enough to slide your hands in) and tighten the frame. I hear its not bad, I need to do mine. Someone posted the procedure here before I think.
Old Nov 11, 2005 | 03:36 PM
Daehtihs's Avatar
I have the same problem. It seems to go away when I stick a finger or two into the rubber accordian looking pieces on each side. Definately not the usual sunroof squeek.
Old Nov 15, 2005 | 01:14 PM
timElinE's Avatar
i had that problem before too but i just took it into the dealer when i got my oil change and the fixed it. now when i tilt open the sunroof, it makes a rattling noise during the transition =(
Old Nov 15, 2005 | 01:41 PM
Jiwon's Avatar
Is sunroof squeak well-known problem by Nissan ?
I've had that **** for a year and I took it in to dealer and showed to technician
He had no idea where it was coming from even though I told him it was coming
from sunroof. Is there anyway I could fix this annoying problem ?
It only squeaks when I got uneven road like going into parking lot. (Little ramp
that almost every porkitng lot has)
It also squeaks when I push the sunroof or the top.
Dallsinghjr1
Sep 17, 2023 11:25 AM
G35xdriver04
Nov 7, 2015 08:31 PM
NailBomb
Oct 28, 2015 07:53 AM
G35-2004-mt6
Sep 11, 2015 04:16 PM
