Oil change at the dealer
Old Nov 25, 2005 | 12:57 PM
gto2050's Avatar
Question Oil change at the dealer
I had my 6MT serviced today at Ramsey Infiniti. I was talking to the service rep and I asked about synthetic oil. He said that Infiniti does not recommend synthetic oil. I was quite surprised to hear that. Anyone else been told this?
I went ahead with regular oil at that point.
I took the car to a friend of mine's garage after that to see how difficult it would be to change it yourself. I have quickly seen the aero cover over the bottom of the engine and wanted to see how difficult it was to remove and get to. I put the car on the lift and lookeed under and took a few pictures as well. I was surprised to see a rectangular cutout (2" X 6") right around the drain plug. Mine is an 03 so I am sure that not too much has changed.
I read where the cover has to be removed to change the oil. There was no oil residue around the opening so maybe they still take it off. I think they still have to remove part of the cover to get to the filter.
Anyone got any advice/knowledge around this subject??
Old Nov 25, 2005 | 04:36 PM
mwarsh1's Avatar
i have an o5 and they ha to unscrew, to get the filter on, i think im 99 percent sure.
Old Nov 25, 2005 | 05:03 PM
Msedanman's Avatar
O.F. Administrator
Yes I believe it's still in the owner's manual to not use synthetic oil.....don't know why...I think most ignore that and use it anyway since it's a better oil.
..and most dealerships install synthetic too...
The oil can be changed without removing that cover but it's much easier and cleaner to remove it. Not a big deal.
C.
Old Nov 25, 2005 | 05:08 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
^^ I agree..
I know my dealer carries Mobil1.
& yes the dealer drops the tray to change the oil.
They only drop the back bolts & let it hang from the bumper.
Old Nov 25, 2005 | 05:17 PM
gary c's Avatar
Oil change.......
Holy $hit, you can't listen to service advisors. They are nothing more than
salespersons that want to spend your $.Plus this one doesn't know jack about what you should be using! You need to use synthentic oil
if for no other reason than it's better for your car! It's also important
that you change your oil and filter every 3,000 miles regardless of what
type of oil you use. Mobil I.....Royal Purple use only pure synthentic oil
you won't be sorry and you can sleep at night knowing your doing the
best you can for your Gee
Old Nov 25, 2005 | 06:50 PM
TheKnite's Avatar
Interesting
Lynnes Dealership charges my cousin $80 for an oil change, since they claim they use synthetic for his FX35 which has the same engine, so I don't know.
Old Nov 25, 2005 | 07:27 PM
gto2050's Avatar
Interesting. You would figure that the dealer would want to make more money by selling you synthetic!
Old Nov 25, 2005 | 07:30 PM
Queens350z's Avatar
Z SQUAD
$80 seems to be a little too much for an oil change.
Luis
Queens350Z
Old Nov 25, 2005 | 07:32 PM
gto2050's Avatar
$80 for synthetic as opposed to $34.99 for regular oil.
Old Nov 25, 2005 | 09:07 PM
FAST1's Avatar
It's also important
Why in the world would you use synthetic oil if you change your oil every 3K miles? Anyone who uses dyno oil and changes it every 3K miles will easily get 200K miles on almost any modern engine. If you buy a Porsche TT and follow the factory recommendation, you'll change your oil around every 12K miles. And if I'm not mistaken the oil filter is only replaced every other oil change. So why would Porsche have these long oil change intervals on a $150K car if they thought that changing oil every 3K miles would be better? Keep in mind that Porsche, unlike BMW and Audi, charges for its maintenance.
Old Nov 25, 2005 | 09:58 PM
bltzkrg's Avatar
Service manual procedure for oil change...
MA-15
1. Remove engine undercover with power tool.
2. Warm up engine, and check for oil leakage from engine components.
3. Stop engine and wait for 10 minutes.
4. Remove drain plug and oil filler cap.
5. Drain engine oil.
 Install drain plug and refill with new engine oil.
Oil specification and viscosity:
 API Certification Mark
 API grade SG/SH, Energy Conserving I & II or API grade SJ or SL, Energy Conserving
 ILSAC grade GF-I, GF-II & GF-III
Refer to MA-9, "RECOMMENDED FLUIDS AND LUBRICANTS" for furthur detail.
MA-16
ENGINE MAINTENANCE
Oil capacity (Appoximate):
Unit: (US qt, lmp qt)
CAUTION:
 Be sure to clean drain plug and install with new washer.
 When filling oil, do not pull out oil level gauge.
 The refill capacity depends on the oil temperature and drain time. Use these specifications for
reference only.
 Always use the dipstick to determine when the proper amount of oil is in the engine.
6. Warm up engine and check area around drain plug and oil filter for oil leakage.
7. Stop engine and wait for 10 minutes.
8. Check engine oil level. Refer to LU-6, "OIL LEVEL" .
Changing Oil Filter ALS0006P
REMOVAL
2. Using an oil filter wrench (special service tool), remove the oil filter.
CAUTION:
 The oil filter is provided with a relief valve.
Use genuine NISSAN oil filter or equivalent.
 Be careful not to get burned, the engine oil may be hot.
 When removing, prepare a shop cloth to absorb any oil
leakage or spillage.
 Do not allow engine oil to adhere to the drive belts.
 Completely wipe off any oil that adheres to the engine
and the vehicle.
INSTALLATION
1. Remove foreign materials adhering to the oil filter installation surface.
2. Apply engine oil to the oil seal contact surface of the new oil filter.
Drain and refill
With oil filter change Approximately 4.7 (5, 4-1/8)
Without oil filter change Approximately 4.4 (4-5/8, 3-7/8)
Dry engine (Overhaul) Approximately 5.4 (5-3/4, 4-3/4)
Oil pan drain plug:
: 29.4 - 39.2 N·m (3.0 - 4.0 kg-m, 22 - 28 ft-lb)
PBIC0819E
SMA010
ENGINE MAINTENANCE
A
B
3. Screw oil filter manually until it touches the installation surface,
then tighten it by 2/3 turn. Or tighten to specification.
4. After warming up the engine, check for engine oil leakage.
5. Check oil level and add engine oil. Refer to LU-6, "OIL LEVEL" .
6. Install engine undercover.
Oil filter:
: 14.7 - 20.5 N·m (1.5 - 2.1 kg-m, 11 - 15 ft-lb)
Recommended fluids...
C
D
E
F
G
H
I
J
K
M
A
B
MA
RECOMMENDED FLUIDS AND LUBRICANTS PFP:00000
Fluids and Lubricants ALS0006H
*1: For further details, see “SAE Viscosity Number”.
*2: Using automatic transmission fluid other than Nissan Genuine ATF Matic Fluid J will cause deterioration in driveability and automa-
tic transmission durability, and may damage the automatic transmission, which is not covered by the INFINITI new vehicle limited
warranty.
*3: Genuine Nissan PSF II, Canada NISSAN Automatic Transmission Fluid, DexronTM III/MerconTM , or equivalent ATF may also be
used.
*4: Available in mainland U.S.A. through your INFINITI dealer.
SAE Viscosity Number ALS0006I
GASOLINE ENGINE OIL
SAE 5W-30 viscosity oil is preferred for all temperatures. SAE
10W-30 and 10W-40 viscosity oil may be used if the ambient
temperature is above -18°C(0°F)
Capacity (Approximate)
Recommended Fluids/Lubricants
US measure Imp measure Liter
Engine oil
Drain and refill
With oil filter
change
5 qt 4-1/8 qt 4.7  API Certification Mark*1
API grade SJ or SL, Energy Conserving*1
 ILSAC grade GF-I, GF-II & GF-III *1
Without oil filter
change
4-5/8 qt 3-7/8 qt 4.4
Dry engine (Overhaul) 5-3/4 qt 4-3/4 qt 5.4
Cooling system
With reservoir
tank
9-1/4 qt 7-5/8 qt 8.7 Genuine Nissan Anti-freeze coolant or equivalent
Reservoir tank 7/8 qt 3/4 qt 0.8
Manual transaxle gear oil 3-1/4qt 2-3/4qt 2.9 API GL-4, Viscosity SAE 75W-85 or 80W-90
Automatic transmission fluid 10-7/8 qt 9-1/8 qt 10.3 Nissan Genuine ATF Matic Fluid J *2
Power steering fluid 1-1/8 qt 7/8 qt 1.0 Genuine Nissan PSF II or equivalent*3
Brake fluid — — —
Genuine Nissan Brake Fluid*4 or equivalent
DOT 3 (US FMVSS No. 116)
Differential gear oil 3 pt 2-1/2 pt 1.4 API GL-5*1, Viscosity SAE 80 W-90
Multi-purpose grease — — — NLGI No. 2 (Lithium soap base)
MMA117AA
Old Nov 25, 2005 | 10:35 PM
player's Avatar
i was at ramsey infiniti at around 9am today
Old Nov 25, 2005 | 10:47 PM
gto2050's Avatar
Me too. Red 6MT. I was wearing a black leather jacket and an HD baseball cap.
Old Nov 25, 2005 | 10:57 PM
Blackbird V35's Avatar
somebody misinformed you
Old Nov 25, 2005 | 11:19 PM
antdiesel3's Avatar
I had an 04' WRX before my G. I was told by a rep from Subaru of America that Subaru recommended using conventional oil in their engines. His reason was that all of their engines are designed and tested using conventional oil.
I'm thinking maybe Infiniti has a similar take on oil usage Just my .02
