Installing iso thermal plenum spacer yourself?
Old Dec 28, 2005 | 01:29 PM
99atlantic's Avatar
How hard per-say is the install if you do it yourself and have almost 0 car knowledge? (e..g, I don't even own a torque wrench, would have to go buy oine, lol). The 3 things that really worry me are
- Dropping something into the open manifold/intake/wtf that is :/
- Not being able to put the upper/lower plenum back together
- Having to cut into the coolant line to install the valve :/
Old Dec 28, 2005 | 01:36 PM
SilverII's Avatar
it is suppose to be a bolt on item... should be medium to easy...
Old Dec 28, 2005 | 01:39 PM
Devil Dog's Avatar
- Dropping something into the open manifold/intake/wtf that is :/:/
That phrase right there leads me to recommend that you take it to someone a 'tad' bit more knowledgeable.
Old Dec 28, 2005 | 01:42 PM
ChicagoX's Avatar
Don't drink and Mag Race
It's an easy install. No cutting required.
You might want to invest in one of those small magnetic pick-ups if you are prone to 'dropping things"
Old Dec 28, 2005 | 02:23 PM
99atlantic's Avatar
then how do you install the valve in the coolant line? The instructions clearly say 'cut 1 1/2'' segment from line'.....
Old Dec 28, 2005 | 03:50 PM
g35rcr's Avatar
if you get the copper iso thermal there is no cutting since it uses a throttle body plate...pay the extra for the copper you cheapo!
Old Dec 28, 2005 | 04:03 PM
SCoupe's Avatar
Yeah . . . . listen to dog.
Old Dec 28, 2005 | 04:06 PM
cato's Avatar
SouthernComfort Moderator
Check this out.
https://g35driver.com/forums/intake-exhaust/71386-group-install-iso-thermal-gasket.html
cut and past this into the Address to see an install
Old Dec 28, 2005 | 04:43 PM
Disco_Monkey's Avatar
Easy stuff.
I didn't have an INCH/POUND torque wrench so I used a DRIVER handle with a 10mm socket and just hand tightened everything.
DO NOT USE A FOOT/POUND torque wrench, you will snap the bolts. Just follow the directions as precisely as possible.
Old Dec 28, 2005 | 08:22 PM
Andy2434's Avatar
Actually, the MREV install was relatively simple. I used a serrated knife to cut the coolant line for the CCV install. Since then, I have installed the copper heating plate.
If you can read and follow Tony's instructions, you should have a fairly easy time of it. However, if you are uncomfortable installing the MREV, I would highly suggest having someone else perform the install. I had not worked on a car for some 20 years and found it quite simple.
Either way . . . You will have a blast with the MREV . . . Enjoy!
Old Dec 28, 2005 | 09:26 PM
maxpower's Avatar
are you installing the at or mrev version? the at version is easier....see thread from Cato above. the coolant line is rubber and easy to cut
Old Dec 28, 2005 | 10:04 PM
Andy2434's Avatar
Sorry about that. I misread your post. You are essentially still installing the exact same things.
Old Dec 28, 2005 | 10:23 PM
MikeStarrG35's Avatar
Obsessive Owner
I just installed my MREV a few hours ago. It took me about 3 hours. It really was the first time ive ever done mechanical work on a car. Was not difficult.
Old Dec 29, 2005 | 02:07 AM
G32082's Avatar
When ever my lazy *** decides to order ill take it to my mechanic which has been doing my cars for about 5 years now
JMFeld02
Intake & Exhaust
Feb 25, 2016 07:50 PM
CoupeObsession
Aug 17, 2015 01:05 PM
Raven7
Aug 14, 2015 04:40 PM
deathsupport
Canada
Aug 2, 2015 10:13 AM
