Revup Engine vs. Non revup
Old Dec 31, 2005 | 10:48 PM
ParadoxDHL's Avatar
I know that the Revup engines in the 05+ 6mt's lost 10 torque but gained 18 Hp. I'm just wondering what did that. I know so far it was
1. "electronic exhaust valve timing control"
2. "revised pistons"
3. "higher lift and duration camshafts"
4. Lower plenum redesigned ( http://infinitipa.zoovy.com/product/14010-AC805 )
Q1. The newly designed lower plenum in the 05's are the same price as the older design, and i'm wondering if its worth it (performance wise) to get the new lower plenum for my 04.
Q2. Where can i get valve timing components from and are these worth it as well if money wasn't a factor?
Old Jan 1, 2006 | 07:01 AM
LIUser's Avatar
1. probably not
2. money not a factor... TT it, but if u want it im sure u can get it off infiniti somehow
Old Jan 1, 2006 | 02:25 PM
g'dup13's Avatar
jus get the half inch spacers from motordyne.. it will give u atleast 10 to 15 more horses to the wheel.. and ur baseline will b the same as a stock 05 or 06
Old Jan 1, 2006 | 03:48 PM
EricIsKlumzyee's Avatar
stiffer rods, different ecu, rod bolts, A&F sensor?
no not worth the money
Freeman186
Sep 6, 2023 10:07 AM
alessandro
Oct 8, 2015 09:29 AM
Joe Gargano
Sep 18, 2015 11:17 AM
AT23
Sep 15, 2015 07:44 PM
AuAltima3.5
Sep 13, 2015 10:53 AM
