need help
Old Jan 1, 2006 | 03:33 AM
MJ_G_35's Avatar
need help
Today, I found out left engine cover screw broken in half and broken part stuck in the plenum screw hole. I didn't do anything with it.
it looks like the plenum cannot be fixed unless replaced with new one.
I need to install spacer but have to fix this first..
Is that under the warranty..??
Old Jan 1, 2006 | 10:47 AM
g35rcr's Avatar
you can go get a bolt extractor from sears if the dealer trys to charge you to take it out...it can be taken out, my dealer took mine out for free when i asked them
Old Jan 1, 2006 | 02:11 PM
Jtrain's Avatar
Take it to the dealer fo rsure
Old Jan 1, 2006 | 02:15 PM
Andy2434's Avatar
Hmmm . . . If you are really careful, you can drill the bolt and use an easy out bit to remove the broken bolt. If you are unfamiliar with this process, I would take it back to the dealer or have someone else do it for you. Good luck!
Old Jan 1, 2006 | 03:52 PM
MJ_G_35's Avatar
Unfortuneatly,
My engine cover bolt was bent when I first unscrew and install Z-tube.
I tried easy out/bolt out to extract broken bolt.
I guess $ucking screw didn't come out and make it worse because screw bent and stuck hard in screw hole.
Well, now..
I realize easy-out didn't work out.
I can't even bring it to the dealer.....
you guys think dealer still can fix it ?
BTW Damn screws are so weak.
Old Jan 1, 2006 | 03:55 PM
EricIsKlumzyee's Avatar
next time hand tighten first before u use a rachet!!
Old Jan 1, 2006 | 03:58 PM
MJ_G_35's Avatar
Definately....
Old Jan 2, 2006 | 08:02 AM
MJ_G_35's Avatar
Oh yeah..
I just parted out upper plenum and tried easy out again.
I put my weight on drill and broken bolt came out. lol
What I learned?
always "hand tighten!!!!!!!!" first
thanks for the info.
Happy New Year
