MREV torque wrench?
Old Jan 2, 2006 | 01:38 PM
g35doc's Avatar
MREV torque wrench?
What in-lb torque settings are needed to install the MREV? I'm trying to figure out what kind of torque wrench to get beforehand.
Old Jan 2, 2006 | 02:56 PM
Andy2434's Avatar
The inch-lbs. torque wrench settings, which you will be working with during your MREV install range from 30 inch-lbs. to 100 inch-lbs.
I trust you have a great post MREV install experience. Enjoy!
Old Jan 2, 2006 | 03:23 PM
g35doc's Avatar
Thanks. I'm going to preorder the MREV this week. Looks like I'll be getting the $65 craftsman wrench (25-250 in-lb) but that's on backorder too.
Old Jan 2, 2006 | 03:34 PM
Andy2434's Avatar
Good deal, that will work.
Old Jan 2, 2006 | 03:38 PM
Jee_35's Avatar
exactly how do you know what to set the torgue wrench to when you're working on MREV and even the cats and exhaust part of the car? I found out that the wheels need to be torgued at 80, but how do you know for all the other little nuts and bolts? sorry... <------------- NOOB :P
Old Jan 2, 2006 | 03:43 PM
g35doc's Avatar
It should be specified in the instructions for each type of bolt.
Old Jan 2, 2006 | 03:55 PM
ChicagoX's Avatar
Don't drink and Mag Race
In the FSM, every bolt is markedwith a torque spec, as the above poster mentioned.
Old Jan 2, 2006 | 04:04 PM
VQdriver's Avatar
is it possible just to hand tighten everything with no problems?
Old Jan 2, 2006 | 04:13 PM
Andy2434's Avatar
Jee_35,
With regard to the MREV install . . . Tony provides detailed written instructions with pictures . . . And as such, Tony has numbered the bolts per their tightening sequence and the associated torque setting requirements. The said instructions made the install task quite simple for me.
Old Jan 2, 2006 | 04:23 PM
99atlantic's Avatar
I think all the questions in this post can be summed up in 1 word -> RTFM!
or alternatively
DTFMFTMDWSATRTFM!!
Old Jan 2, 2006 | 04:24 PM
Andy2434's Avatar
Absolutely . . . Yes, it is possible to tighten everything down by hand and experience no problems. However, I would advise using a inch-lb. torque wrench. The trick here is to tighten down all of the plenum bolts down with an evenly distributed force across the plenum . . . This is to insure against a vacuum leak and the potential snapping of bolts.
Old Jan 2, 2006 | 04:29 PM
Jee_35's Avatar
thanks for the info guys, appreciate it greatly
Old Jan 2, 2006 | 04:31 PM
Andy2434's Avatar
or alternatively
DTFMFTMDWSATRTFM!!
LMAO . . . Some people simply need to be reassured, as with myself. I have often find myself lurking throughout many of the posts seeking the right information. When I am unsure of myself . . . I will ask what may appear to be a silly question to many. However, I'd rather ask a silly than potentially make a big and costly mistake. Understanding that, I will always afford a courtesy answer. These boards have been a life saver for me, at times.
Old Jan 2, 2006 | 04:39 PM
Devil Dog's Avatar
I hand tightened everything when I installed my MREV.
Old Jan 2, 2006 | 07:41 PM
MikeStarrG35's Avatar
Obsessive Owner
As did I. But I overtightened a bolt on the intake manifold (using regular socket wrench) and it snapped. Tony said he did the same thing and it is fine to run with for now. I will be geting a bolt removal kit and installing a new bolt. Runs great now though
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
boostelevator
Engine - Intake/Fuel
12
Jan 12, 2016 11:35 PM
bigmike
Sep 17, 2015 01:58 PM
yosip1115
Aug 26, 2015 10:46 AM
