VDC & Slip Light Keep Turning On
Old Jan 18, 2006 | 05:13 PM
STL_G's Avatar
The last 3 or 4 times I start my car and go my VDC & SLIP light go on. If I restart they will stay off. What is this?
Old Jan 18, 2006 | 05:24 PM
Godfather's Avatar
its probably the Snow or bad weather....
Old Jan 18, 2006 | 05:27 PM
Beowulf's Avatar
the vdc system maybe glitching if its staying on. you may have to take it into the dealer.
Old Jan 18, 2006 | 06:02 PM
Deang35c6's Avatar
Have you changed anything with the car?
Old Jan 18, 2006 | 06:07 PM
STL_G's Avatar
No snow or rain, only dry pavement. I have not added any mods to the car. It simply just started doing this this week.
Old Jan 18, 2006 | 06:11 PM
truplay8's Avatar
THE BATMOBILE
take it to the dealer
Old Jan 18, 2006 | 06:38 PM
636Racer's Avatar
I read some of your recent posts...did you change your tires?
Old Jan 18, 2006 | 07:13 PM
Deang35c6's Avatar
Yes, even tires can affect VDC.
Old Jan 18, 2006 | 07:21 PM
STL_G's Avatar
I changed my tires about 2-3 months ago. Thank you all for your help, I guess I will swing by the dealer.
Old Jan 18, 2006 | 07:29 PM
RockG's Avatar
Might be your throttle body going bad. Either way, have the dealer check it out.
Old Jan 18, 2006 | 07:52 PM
GRider35c's Avatar
i cant believe nobody got it right yet...
its an indication of low brake fluid, low brake pads...
Old Jan 18, 2006 | 08:06 PM
STL_G's Avatar
Grider, I bet U R right. I go in for new brakes Monday. My brakes are getting worn. Thank you.
Old Jan 18, 2006 | 10:49 PM
Deang35c6's Avatar
If your new tires didn't keep the .5 to 1 inch stagger in side wall height, VDC will act up also.
Mry
Mar 3, 2023 01:03 AM
SiMpLyMoDiFiEd
The FX-Spot
Dec 2, 2021 04:35 PM
Luisgalvan33
Jul 19, 2018 08:16 PM
Wayne9011
Aug 17, 2015 01:24 AM
Wayne9011
Jul 27, 2015 11:25 AM
