Please! help me find a squeak
Old Feb 1, 2006 | 10:19 PM
Derek173's Avatar
keep us informed please!
Originally Posted by mosdefconor
It sounds like it's coming from the rear wheel on the passenger side and when I called the Infiniti dealership the mechanic said that it might be caused by the fact that my brake pads are worn out and it's rubbing against the rotor. That sounds plausible except for the fact that the noise often comes when I'm not even touching the brakes. I'm taking it to the dealer soon and will let you guys know what I hear.
But there is definitely a part rubbing against another. Hope we can get to the bottom of this.
Old Feb 2, 2006 | 12:04 AM
300zx2G35's Avatar
No idea whats going on
Originally Posted by Derek173
Do you guys with lowered suspensions track your car? Im thinking the track days may have worn out a bushing on my car (hopefully sway bushing )
I dont track my car but I do drive it pretty hard on the backroads round here every now and then. I haven't checked my sway bushings but I definately will now since that is what most people seem to think it is.
Old Feb 3, 2006 | 11:49 PM
Destro's Avatar
The noise you are hearing is from the brake warning squeelers touching the rotors. When pads get down to a certain thickness, a piece of metal starts to rub on the rotor and make that noise so you know it's time to change the brakes.
And yes, at first the noise will go away when you brake. When pads get really worn down, they will screech a lot even when braking.
Old Feb 4, 2006 | 06:34 AM
vasqo's Avatar
i also have squeaking coming from my front suspension... it drives me nuts and the worst part is i cant narrow it down any further. Can someon make a list of possible things that may create suspension squeeks? Thanks
Old Feb 5, 2006 | 01:15 PM
Derek173's Avatar
I will be looking into this thanks!
I have dealt with the squeak associated with worn pads but this does not sound like but it doesnt hurt to check the pads
Freeman186
Sep 6, 2023 10:07 AM
zcherub
Sep 10, 2015 12:03 PM
Gwhut?
Drivetrain
Sep 6, 2015 10:07 AM
G35CO
Sep 4, 2015 09:27 AM
kevintandmd
Sep 3, 2015 06:41 PM
