Strange whistling sound when accelerating
Old Feb 6, 2006 | 02:12 PM
2Evolved's Avatar
Originally Posted by kidtronix
Vehicles that are consumer-centric have synchros whose splines are angled (like the impellers within a supercharger). This decreases noise and smooths the shifting of the transmission. Can you imagine how annoying a whiny rally transmission would be if it was your daily driver?
Yes this would be very annoying... my evo although it is US spec, doesn't have much of a whine although it is louder than the G35 but if it was really loud it was more of a transfer case problem.
Old Feb 6, 2006 | 03:19 PM
boakid's Avatar
Hey
I have an 06' 6 mt coupe and hear the same whistling sound your talking about between 3-4 rpm. My car is brand new i guess well just wait and see.
Old Feb 6, 2006 | 03:27 PM
some.devil's Avatar
exhaust... i noticed how it whitles too
Old Feb 6, 2006 | 03:34 PM
heeb's Avatar
Weird. I have a 04 G35 5AT, and only after I got my sound system installed, I noticed that I hear this noise. It sounds much like an electronic whistling noise though.. a bit like a supercharger whine.
Maybe someone installed a supercharger while you weren't looking?
Old Feb 6, 2006 | 03:36 PM
bokinsmowl's Avatar
i'd say its your intake suckig in air...i heard it a little before, but after my z-tube and popcharger install it sounds like i have TT's under the hood, expeciall WOT from 4200-6400 rpm...
Old Feb 6, 2006 | 05:07 PM
G35SHAWN's Avatar
It's normal...no need to worry.
Old Feb 6, 2006 | 05:13 PM
fireblade's Avatar
It sounds like a few people are experiencing it. Just glad i'm not alone here. Like some of the other comments I'm going to wait and see. I'm not even 200 km into my ride yet so...
Old Feb 6, 2006 | 06:25 PM
derek's Avatar
From: Metropolitan South Farmington, not too far from the supercity we all know as Wilmot, NS
Fireblade,
Ref your q- does this whistling continue when the car is warmed up, or at some point, does it stop?
Why? Until warm, when it's cold out, my 05 Coupe exhaust whistles, until the pipes expand and seal. Then all is right with the world. My 03 Coupe did not have this problem.
If it sounds intake related, then check the routing of the vacuum hose coming off the intake. It is long and routed in such a way as for it to be possible for it to be kinked, even slightly. My 03 was in this boat. Reworking the routing such that the hose was free to flow cured the problem in less than 5 minutes. The real plus here is that your performance will improve by making this correction. Find the hose that comes off your intake and follow it. You may want to remove the four bolts and engine cover to do so- easy stuff.
If you have an aftermarket intake or Z-tube, where the hose is connected opposite to its normal "relaxed" position, then you have a higher probability that this is your issue, and the whistling will be more pronounced. Monkeying around with that hose is the most annoying part (albeit minor at that) of any Z-tube install.
Hope this helps.
Cheers,
Derek
Old Feb 6, 2006 | 07:41 PM
fireblade's Avatar
Thanks derek, I will try your suggestiong by looking for a kink. Yeah i heard about the wierd noises when the car is cold but I definitely hear it more than 5-10 minutes in of driving, so I don't think warm up is much of an issue.
Car is completely stock - just got it 2 days ago and I'm still in la-la land...whistle or no whistle.
Originally Posted by derek
Fireblade,
Hope this helps.
Cheers,
Derek
Old Feb 6, 2006 | 07:55 PM
MahdiG35's Avatar
G RIDIN
mine dose the same exact thing (I have a 06 6MT) and mine just started to do it (at around 1300-1500+) and now I have 1800miles. The loudest point is 3-4k on mine also. My mom has a 04 murano and he car dose the samething, but it starts as soon as you hit the gas.
Mahdi
Old Feb 6, 2006 | 11:25 PM
ColdFusion's Avatar
Its a normal sound for 05s and 06's. I wondered the same thing when i got my 05 coming from an 04 coupe. Its a normal sound. Not sure what it is exactly but you're not alone. I dont notice it as much anymore
Old Feb 7, 2006 | 10:02 AM
some.devil's Avatar
Thats due to a bad ground in you sound system
Old Feb 7, 2006 | 10:03 AM
some.devil's Avatar
like i say, exhaust
Dallsinghjr1
Sep 17, 2023 11:25 AM
Marlin84
Apr 1, 2020 12:52 PM
Video Share
Jan 31, 2017 04:00 PM
dcsbh1
Oct 1, 2015 03:15 PM
