please help (coolant)
Old Feb 26, 2006 | 03:09 PM
Derek S's Avatar
hi guys, my engine coolant is VERY low and i wanted to know can i mix different brands or does it have to be the same brand.
Old Feb 26, 2006 | 04:17 PM
conq's Avatar
Should be ok to use any brand, there's one maybe prestone that comes 50/50 with water. Maybe you should find out why you are low on coolant instead of filling it.
Old Feb 26, 2006 | 04:20 PM
Msedanman's Avatar
O.F. Administrator
......sure just don't mix colours. My Infiniti's have come with green coolant, so I should stick with green.
C.
Old Feb 26, 2006 | 04:32 PM
s14roller's Avatar
Just go to the local walmart or something and pick up the Prestone extended life coolant. Green coolant is green coolant which is what the dealerships all told me also but for peace of mind, the new formula from Prestone is able to mix with any brand and any color.
$8 a gallon.
Old Feb 26, 2006 | 04:35 PM
cato's Avatar
SouthernComfort Moderator
The coolant must be for aluminum engines. Infiniti sells Warranty friendly coolant. My radiator failed at around 70K miles....I was stupid enough to put on one of those high pressure Nismo radiator caps on my Sedan..... result was a leaking radiator after 50K miles of using it.. It threw the CEL and I noticed low radiator fluid + coolant spray on the engine interior. The coolant system is too important to neglect...Find out why your coolant level is low!
Old Feb 26, 2006 | 04:38 PM
kenchan's Avatar
^^^ +1 must be the formula for aluminum engines.
just go to the nissan or inf dealer and also grab a bottle of distilled water.
Old Feb 26, 2006 | 05:58 PM
NETSHARK's Avatar
few days ago it was little low it was like 85% so i filled it with water until it reach the COLD line is this okay ??? or the newbie did something wrong :P
Old Feb 26, 2006 | 06:10 PM
ttrank's Avatar
Grocery getter
So, the Nismo high pressure cap caused your radiator to fail? That seems strange from a Nismo product.
MrIP35
Oct 25, 2015 11:13 PM
BradMD_96
Oct 6, 2015 09:31 AM
Usman Ali
Sep 22, 2015 06:59 AM
DRG35R
Sep 16, 2015 05:33 AM
AuAltima3.5
Cooling
Sep 13, 2015 10:46 AM
