Heated Seat Problem
Old Feb 28, 2006 | 12:15 PM
ashadiow's Avatar
Heated Seat Problem
So I tryed to turn on the heated seats today and the passenger side doesn't work. It doesn't light up and it doesn't heat up. I don't know if the wires underneath are loose or if a fuse is blown, what are your thoughts. I would hate to spend a ton of cash at the dealer to fix a wire or a fuse.
Old Feb 28, 2006 | 12:19 PM
jimmyc13's Avatar
Not sure if your forum join date is a good indication of when you got your car, but are you still under warranty?
Old Feb 28, 2006 | 12:20 PM
jimmyc13's Avatar
Another thing....I'd imagine that if your drivers side one works, then it isn't a blown fuse, as they'd both be run on the same one.
Old Feb 28, 2006 | 02:12 PM
ashadiow's Avatar
Car has 39,985 miles on it so no... it is barely not under warranty. I might call to see if my dealer willl still cover it, but I doubt it.
Old Feb 28, 2006 | 04:55 PM
GeeMan's Avatar
I had the same problem. My stupid fix was to bang the area around the button a bit with my hand. That was two years ago and it hasn't acted up since. Felt good too.
Old Feb 28, 2006 | 05:11 PM
timbo's Avatar
Correct me if I'm wrong but I believe that Infiniti's come with a 4yr/60,000 mile warranty. It should still be under warranty. This was one of the reasons for purchasing the Infiniti over the Nissan.
Old Feb 28, 2006 | 05:52 PM
Spd2Last's Avatar
+1 ^
i'm pretty sure its that
Old Feb 28, 2006 | 05:56 PM
drunkin master's Avatar
Are you sitting on the seat when checking? Maybe some spilled something over it. I would def. take it to the dealer. good luck
Old Feb 28, 2006 | 06:04 PM
ashadiow's Avatar
Our standard warranties:
4-year/60,000-mile basic coverage under the New Vehicle Limited Warranty
4-year/60,000-mile Federal Emission Defect Limited Warranty
6- year/70,000-mile Limited Powertrain Coverage
7-year/unlimited-mileage Corrosion Coverage
10-year/unlimited-mileage Seat Belt Warranty
Wow... I thought the basic was 3-year/36,000 and the power train was 5 year 60k... wow.
arora_g35
Apr 16, 2026 02:52 PM
derres
Aug 28, 2015 03:27 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
Rokafor
Jul 29, 2015 11:50 PM
vstypicals
Jul 20, 2015 10:55 PM
