Clutch gone?
Old Mar 20, 2006 | 02:30 PM
G XXXV's Avatar
Clutch gone?
The car revs up almost like its in neutral or free-revving but the car barely accelerates...happens when you really start to give it gas...Clutch fried?? worse?
Thanks
Old Mar 20, 2006 | 02:40 PM
G XXXV's Avatar
Just talked to Dealer...said it sounds like the clutch and they'll have to relace everything dic, pressure plate and throwout bearing...maybe flywheel if i burnt it...sound legit?
Old Mar 20, 2006 | 02:47 PM
GT-Ron's Avatar
Yes, it does. If not covered under warranty, consider upgrading with aftermarket parts.
FI'ed G's Avatar
^+1. I had to change my post.. you beat me.
Old Mar 20, 2006 | 02:52 PM
G XXXV's Avatar
The car is under warrenty but I didn't think they covered friction parts clutch, brakes, etc. I was thinking going NISMO with some fo the parts because the work would still be covered because they are still Nissan/infiniti parts...
Old Mar 20, 2006 | 02:58 PM
FI'ed G's Avatar
If i'm not mistaken since Nissan/Infiniti will always replace the Flywheel when replacing the clutch i saw a post here that he was quoted around $2K. I say go buy JWT clutch or Clutch/Flywheel combo and replace it your self. Plus since clutch is not covered, replacing this mean they won't charge you for labormaybe I'm wrong.
Old Mar 21, 2006 | 06:12 PM
Lojacc's Avatar
if your clutch, throw out bearing, and flywheel are truly shot, then they all will be replaced under warranty. this is if and only if they have no more go left in them. I am telling you this b/c the same thing happened to me: clutch was DEAD, took it to dealership and they confirmed my suspicion. Next day had a brand new clutch, flywheel, and throwout bearing all under warranty. Service manager even brought the old one out to show me how bad it was.
I guess it depends on the dealership, but from my personal experience with the same problem, it is covered under warranty.
They had also agreed to install my clutchmaster Stage 3, provided i got it to them before the new factory parts came in. I was too late so they put in the stock clutch.
good luck man. hope that helped you.
Old Mar 21, 2006 | 11:38 PM
conq's Avatar
Lojacc, what dealer was this and how many miles did you have before your clutch went? Strange that they covered in under warranty.
Old Mar 27, 2006 | 04:24 PM
G XXXV's Avatar
Update: Just got off the phone with the service manager, he has agreed to replace ALL parts with NISMO brand parts for 2k out the door. I tried to talk to him about maybe a JWT package instead but he wanted nothing of it. Worth it??
Old Mar 27, 2006 | 04:33 PM
g35rcr's Avatar
2k for 800-900 dollars worth of parts???
RichardP9
Drivetrain
Oct 26, 2015 11:25 PM
AL8782
Oct 3, 2015 10:26 AM
Jpete
Sep 25, 2015 01:38 PM
bigmike
Sep 17, 2015 01:58 PM
jbmw002
Sep 10, 2015 12:54 AM
