Car Lag
Old Mar 26, 2006 | 01:22 AM
Psycraft's Avatar
Car Lag
so ive been playing around as of late with my bud..and i really dont punch my car too hard..,till recently.. i have a 5at and ive noticed it has lag real bad,i'll punch it,then like 2 seconds later it'll be like oh..now i go..heh.. but when i roll atleast 10mph and then punch it it has better response and the lag is way less noticable..,ive heard that the "stillen" grounding kit takes care of the lag and should get rid of it..am i correct on this? and if not is their a way to get rid of the lag on the car,its quite weird seeing my buds bmw 325,take me from a dead start..my tires spin,and he's already moving.. and gets ahead,then when my car finally starts to go i finally catch up,but once i hit 2nd and 3rd im always passed him
Old Mar 26, 2006 | 01:41 AM
Triji's Avatar
Lightweight pulleys will help you get out of the hole faster.
Also break tourqing to about 1500 RPM's when at a dead stop in an auto helps as well, making sure to take VDC off if it is in a straight-a-way... once you get going turn your VDC back on so you don't lose traction at higher speeds.
Old Mar 26, 2006 | 01:46 AM
Psycraft's Avatar
how much are lightweight pulleys?
Old Mar 26, 2006 | 01:50 AM
Triji's Avatar
I got mine for like 220.00 and I noticed a difference in the pull. The set came with 3, I only installed 2 tho... The alternator is a PITA to change out, I worked on it for a cpl hrs and said screw it.
I went with regular lightweight pulleys and not UR pullieys. I did not want to mess w/ voltage drain.
Old Mar 26, 2006 | 02:05 AM
truplay8's Avatar
THE BATMOBILE
ive never heard about the stillen grounding kit helping this problem..........how ever you should def break tq from now on it helps big time..........i have UR pullies and this addresses the problem some what.......its a start
Old Mar 26, 2006 | 02:45 AM
99atlantic's Avatar
that's as a result of the "great" invention called drive-by-wire ( to drive-by-wire)
Old Mar 26, 2006 | 03:30 AM
Psycraft's Avatar
how do you break tq? im a newbie at this..
Old Mar 26, 2006 | 12:46 PM
truplay8's Avatar
THE BATMOBILE
instead of jst slamming on the peddle in a race........you put your foot on the break and rev up to about 2k rpm.......then you let go of the brake and punch it........search it for more details
Old Mar 26, 2006 | 01:58 PM
arjunz's Avatar
Get the Gordgee grounding wires ... makes a world of a difference
Old Mar 26, 2006 | 03:05 PM
Psycraft's Avatar
i was thinking about the stillen grounding kit..also,are their any other mods i can do to help me get rid of the lag....? thanks for your help
Old Mar 26, 2006 | 03:43 PM
visualfusion's Avatar
Ecu Reset
Old Mar 26, 2006 | 03:48 PM
Psycraft's Avatar
how much is a ecu reset?
Old Mar 26, 2006 | 03:50 PM
D87's Avatar
D87
ECU reset here dude! I tried it and it worked perfectly!
https://g35driver.com/forums/faq-diy/6538-ecu-resets.html
Old Mar 26, 2006 | 03:54 PM
urabus's Avatar
There is no lag in a NA engine. You only experience lag with Turbochargers or Superchargers. The delay or slow response you're experiencing is due to the engine is not operating near it's powerband. Grounding kit will not help because it will not speed the power delivery to your wheels.
Old Mar 26, 2006 | 04:49 PM
99atlantic's Avatar
disconnect your battery (negative terminal bolt) for 24hrs
that pedal method is bull**** and only resets some minimmilistic stuff
btw, lower your windows by ~1'' - they automatically raise/lower, and with the battery disconnected, they won't be able to and if they're fully up you'll scrape the roof line if you open the door.
