Help with measurement needed
Sup gang,
I need some help here. I'm about to re-mount the SKYLINE emblem and need to know the height of the stock "INFINITI" emblem from the edge of the trunk.
I prefer the measurement to be in millimeters as it's more accurate than using inches.
If anyone can run down to his/her car and give me the measurement I would really appreciate it. I would have done it myself, but my car is completely debadged.
Thanks.
Thanks.
Originally Posted by da mayor
50cm to be exact
Edit: Speed, you beat me to it.
I thought it was up to us metric Canadians to catch these things.
Originally Posted by usual_suspect
I think you mean 50mm. 50cm is almost 20 inches.
i'm sorry. i had to measure the ground clearance of a M35x for a customer so i killed two birds with one stone. yea i mean 50mm.... i'm too used to just measuring on the standard size of the tape.
I wasn't born here, so I'm a metric native myself...
Originally Posted by jersey-G
between 2 3/16" and 2 1/4" to the bottom of the lettering, sorry don't have metric at work.
Thanks,
Did you get these numbers at the corners of the emblem, or the center?
The reason I'm asking is because the trunk edge is a little curvy so the distance at the middle of the emblem is not the same as in the corners.
Thanks again!
Originally Posted by Speedoholic
Thanks,
Thanks again!
Thanks again!
measured to the bottom of the first "I" in infiniti
Since the main point of the thread has been answered, I wanted to see if I could get some additional measurements (This way I am not hijacking the thread but taking a 'Continuing Flight'
I am having my all of my decklid emblems re-installed: the Infiniti Lettering, the Mt Fugi, and the G35. Can anyone measure the distance the top of the Mt Fugi emblem should be from the top of the decklid? Also, is it exactly centered from left to right as well? Likewise, could someone get the measurement that the "Infiniti Lettering" is from each side of the tail-lights ( measurement from the left-side "I" to the deck lid edge by the left tail-light and measurement from the right-side "I" to the deck lid edge by the right tail-light). Also, measure the location of the G35 emblem. My body shop totally screwed up and I want to get them correct measurements so they can apply them emblems correctly.
). I am having my all of my decklid emblems re-installed: the Infiniti Lettering, the Mt Fugi, and the G35. Can anyone measure the distance the top of the Mt Fugi emblem should be from the top of the decklid? Also, is it exactly centered from left to right as well? Likewise, could someone get the measurement that the "Infiniti Lettering" is from each side of the tail-lights ( measurement from the left-side "I" to the deck lid edge by the left tail-light and measurement from the right-side "I" to the deck lid edge by the right tail-light). Also, measure the location of the G35 emblem. My body shop totally screwed up and I want to get them correct measurements so they can apply them emblems correctly.
