NEED HELP ASAP!!! PLEASE HELP!!! Front wheel dosen't fit!!
Old Apr 7, 2006 | 03:30 PM
MahdiG35's Avatar
G RIDIN
I just got my TSW thruxtons and my back ones got on prefectly but when I took my front wheel out, there is and extra bolt with a 12mm bolt on it (beside the 5 wheel studs, where the lug nuts go on).
PLEASE HELP ME ASAP!!! MODS please don't move the thread because I need help asap.
I have 06 6MT Coupe.
Old Apr 7, 2006 | 03:32 PM
Derek S's Avatar
take it off you dont need that
Old Apr 7, 2006 | 03:36 PM
MahdiG35's Avatar
G RIDIN
how do i take it off, with out the rotor spininng?? when i put force on it it truns.
Old Apr 7, 2006 | 03:37 PM
madchef's Avatar
That bolt is to prevent you from putting the wheels in the wrong location (for instance, putting the rear wheels on the front)
Just make sure the tire reads correctly:
Front:225/40-19
Rear: 245/40-19
Old Apr 7, 2006 | 03:38 PM
Derek S's Avatar
you have to hold it down i guess. my tire shop took it off for me.
Attached Thumbnails NEED HELP ASAP!!! PLEASE HELP!!! Front wheel dosen't fit!!-x.jpg   NEED HELP ASAP!!! PLEASE HELP!!! Front wheel dosen't fit!!-xx.jpg
Old Apr 7, 2006 | 03:39 PM
madchef's Avatar
Oh, if you are putting aftermaket wheels on, then just remove the bolt (grab the rotor with your hand to hold her steady)
Old Apr 7, 2006 | 03:44 PM
binar's Avatar
Have someone push on the brake. That will keep the rotor from turning.
hummm deee dummmm waiting for my new wheels......
Old Apr 7, 2006 | 04:15 PM
G35PhatS4's Avatar
G SQUAD
That bolt is on there so we don't have idiots putting rear OEM tires on the fronts...
It might be on a lil tight and need a lil force to get it off... Spray some WD40??
Take that bolt off and you're good...
Old Apr 7, 2006 | 04:16 PM
HansMoleman's Avatar
or if you are by yourself put a screw driver in the vents of the brake rotor so that it wedges against the caliper.
Old Apr 7, 2006 | 05:13 PM
MahdiG35's Avatar
G RIDIN
thanks guys. I just holded the rotor and turned it and it unscrewd pretty easily. now I am at nissan and they are trying to put on the tps on there and they say that tps might sit in a bad angle and if I hit a bump then it can crack. they have not took the wheels off the car yet, so they r not sure. has anybody expreinced this problem, were the tps breaks in a aftermarket wheel because it's sittin in a bad angle??? I got 245/35/20 and 285/30/20,
Thanks
Mahdi
Old Apr 7, 2006 | 06:52 PM
Andy2434's Avatar
They mounted rubber valve stems on your new wheels?
Old Apr 7, 2006 | 07:46 PM
MahdiG35's Avatar
G RIDIN
They could not do it, because they were afarid that they were going to scartch my wheels. So I am going try to find a good shop that can do it.
Again thanks a lot for everybody's help!
Mahdi
Old Apr 7, 2006 | 07:47 PM
MahdiG35's Avatar
G RIDIN
nope.
Old Apr 7, 2006 | 10:25 PM
papagz's Avatar
im sure they could do it, theyre just lazy.
they can put it on
Cajuncowboy
Jun 21, 2021 09:47 AM
rezendvous420
May 31, 2020 01:26 PM
Xfactor
Dec 1, 2019 12:52 PM
rping
Jul 26, 2015 09:53 PM
TheefrshstVQ
Jul 26, 2015 09:37 PM
