ECU, Crawford, or Headers, Which One should I get?
i am in the market for either a technosquare ecu, crawford plenum, or a pair of borla headers. i was wondering what all you people out there think i should get. my main concern is that i don't want any problems when i go to the dealer. let me know
<P ID="edit"><FONT class="small"><EM>Edited by wreck on 09/07/03 08:02 PM.</EM></FONT></P>
Guest
Posts: n/a
Re: ECU, CRAWFORD, OR HEADERS, WHICH SHOULD I GET?
Technosquare ECU, in my opinion. I think it will have the biggest effect on the performance of your car. It will really make the power noticeably better without having to deal with the added noise of headers.
If I got one mod, it'd be the crawford. I hear the borla headers don't do much and I can't bring myself to pay 700 bones for a freaking flash upgrade.
plenum, I heard the ECU for the coupe won't make that much of a difference.
2003 G35 Coupe 6mt Diamond Graphite
AIM= bkchang79
AIM= bkchang79
i would do the plenum because out fo all the mods u said that one will give u the most power. Though it is going to obvius that u have. Then maybe down the road i would get the ECU but from what i have herd techno square will make a ne ECU program that will work better with the Plenum. Good luck and let us know what u end up doing.
plenum
G35c 6MT DG/Willow/HyperGround/BorlaExhaust
Do a search. It replaces the top of the stock plenum (intake manifold) with a modified (larger in the front) plenum that equalizes the air fed to the front and rear cylinders. The stock one strangles the fronts (30% less air than the rears). There's much written about it here and at my350z.com. If you care about performance, it's a must do mod.
Lou
Lou
like lowrider said..... the stock plenum (feeds air into the cylinders) limits cylinders 4, 5, and 6 by as much as 30% less air than the top 3 cylinders. The Crawford plenum is a mod'd plenum which increases airflow so that the air restriction difference is only 5%. It is good for 10-15HP above 3,500RPM and costs $500
MrElussive, I'm waiting on my Crawford now-- should have it installed sometime this week. I'll post with pics etc.
Check out Crawford's website, along with posts on our site. It's been described as one of the best mods to make short of FI.
I got mine thru StrictlyZ
Here's the link to
Crawford Plenum
<font color=red>GSM</font color=red> <font color=black>Silverstone Coupe</font color=black>
Here's the link to
Crawford Plenum
how much did you pay through strictly z? plus would the engine cover be able to fit over the plenum and be able to close the hood?
Guest
Posts: n/a
Thanks for the advice and link, guys. I have been looking for a mod for my G35C, and I was considering the Technosquares ECU...I think I'll go with this Crawford Plenum now since everybody recommends it so much. =)
Guest
Posts: n/a
I just checked out the link, and I'm probably gonna go through with it (deciding either to spend my $500 on the Nav-TV or the Crawford Plenum). Can I put the original engine cover back on, after installing the new plenum??
Forgive my ignorance--
if this replaces the intake "manifold", does that mean that you can also get a cold-air-intake to get even more gains? or is it just one or the other?
OK, i win rookie of the year regarding mods!
G35Coupe B/B 6MT Aero/Premium
