Wheres the Trunk trigger wire? (ppl that have added on shock sensor, to OEM alarm)
Old Apr 20, 2006 | 07:05 PM
aleok's Avatar
i just cant wait! anyone know where the trunk trigger wire is under the dash?? i can't find anything that looks like the 1st and 2nd pic in this...
where the hell is it (the red/white wire)?
http://boostedconcepts.forumup.org/a...dconcepts.html
Old Apr 20, 2006 | 07:19 PM
LjN_728's Avatar
First of all, the link dunts work. Secondly...why you hooking it up to the trunk tigger wire when you should hooking it up to the hood pin switch?
Mines
EDIT: Here's the correct link: http://boostedconcepts.forumup.org/a...dconcepts.html . Follow these instructions for an easier installation: http://g-owners.com/article_read.asp?id=43
Old Apr 20, 2006 | 07:53 PM
aleok's Avatar
sorry
i wanna hook it up under the dash because its possible. i wanna get it away from the heat of the engine. i also don't wanna have to drive anywere to get extra wires and terminals. anyone know?
Old Apr 20, 2006 | 09:01 PM
SixFive's Avatar
I've had mine on for 2+ years and the heat of the engine has not been a problem. In fact the setting accuracy is very sensitve and it stays spot on at the precise setting I want month over month. Your better off putting them in the door and the engine compartment. No one can break into the trunk without a prybar as there is no keyhole or visible latch. Whatever you wanted to save with a shock sensor is gone if the bandit has a prybar.
Old Apr 20, 2006 | 09:03 PM
aleok's Avatar
no i don't put the sensor in the trunk i put it under the dash, im only using the truck wire (acting like the hood pin wire), which is under the dash.
Old Apr 20, 2006 | 10:20 PM
aleok's Avatar
nm i got everything down! thanks boostedconcepts!!!
tal1412
Nov 28, 2022 09:25 AM
stay_tuned
Jul 21, 2015 07:09 PM
.cakestar
Audio/Video/Electronics
Jul 17, 2015 08:22 PM
