May 15, 2006 | 09:50 PM
has anyone put the same size rear tire on their front wheel running 19s? i was thinking of putting the 245/40/19 on the front and 255/40's on the rear... i'm not so much worried about the rear as i know it will fit... but, the front...i'm worried about scrubbing on full turn...and whether or not the tire will actually stick too far off of the wheel and look odd...
can anyone atest to how this runs and looks?
btw, no lowering kit here...just stock suspension...
thanks!
Reply 0
May 15, 2006 | 10:04 PM
245 front, and 255 rear should fit in OEM 19s. run/Look should be pretty much the same.
Reply 0
May 16, 2006 | 11:09 AM
Try 245/35/19 front, and 265/35/19s. It will make your G look sooo much BETTER
Reply 0
May 16, 2006 | 07:41 PM
I put 245/35/19 on the front & 245/40/19 on the rear. I didn't want to go any wider on the rims because they're only 8" in the front & 8.5" in the back.
Reply 0
May 16, 2006 | 07:45 PM
u can squeeze a 275 in the rear
Reply 0
May 16, 2006 | 07:48 PM
Quote: has anyone put the same size rear tire on their front wheel running 19s? i was thinking of putting the 245/40/19 on the front and 255/40's on the rear... i'm not so much worried about the rear as i know it will fit... but, the front...i'm worried about scrubbing on full turn...and whether or not the tire will actually stick too far off of the wheel and look odd...
thanks!
If your going to Run 19's ... run a 255/35/19 it fits perfect...(as long as the offset if proper)
Reply 0
May 16, 2006 | 09:35 PM
255/35/19 Fr 285/35/19 Rr
Reply 0
May 17, 2006 | 02:15 AM
would running a 235/35/19 F and 255/35/19 R on OEM 19's mess up the staggered ratio enough for the VDC to not function properly?
Reply 0
